Originally Posted By: millerbl00
Like I said before you can not compare airplanes to cars. Cars are operated in a much harsher conditions by untrained people, some who do no maintenance at all unlike an airplane. Cars have to be over engineered to take the abuse. Right now they are being under engineered.
I disagree.
The airplane routinely operates in -65 degree temps, with the entire structure under the strain of pressure differential and aerodynamic loads. Airplanes are exposed to chemicals, to corrosion, to extremes of temperature, to stretch and compression of the entire structure, and they are far harder to inspect than cars. They can't be over engineered because of weight.
Driving down a road, even a rough road, is a far simpler operating environment. Car engineers simply overbuild the structure. Simple structures with simple engineering.
I disagree.
