Originally Posted By: Boss302fan
Hi guys,
I am installing a new Aluminum radiator in a Boss 302 with a rebuilt boss engine. Which coolant would be best in this set up? The hp is in the 450 range so I need to keep it cool. I am not really sure if all the coolants are good with aluminum or if one is specifically set up for this application. Thanks.
The way I see it you have two clear choices, and one possible alternative.
Choice 1: conventional green silicated coolant. Advantage: its what Boss 302s always had, and silicates protect aluminum extremely well. Disadvantage: its getting harder to find, and I'm afraid that soon the "house brands" will be some form of a "universal" coolant of unknown heritage. Its also a short-life coolant and abrasive silicates can begin to precipitate out in about 2 years.
Choice 2: G-05. Advantage: The metallurgy of your cooling system is really no different than a modern Ford Modular or Chrysler Hemi, and G-05 is what both Ford and Chrysler use to protect their modern iron-block engines with lots of aluminum in the system including the radiator core. Its a modern coolant and will be available as far into the future as any coolant might be. Disadvantage: apparently its not easy to find everywhere. I can walk into my local Sclep Boyz, NAPA, O'Reilly, and several others and find Zerex G-05 concentrate on the shelves, but I gather that isn't so everywhere.
The other possibility: An Asian car phosphated HOAT antifreeze like Zerex Asian Vehicle. This is a little more of an unknown- it theoretically *should* be fine, but its the newest kid on the block and how well it works in old engines is unproven.
For what its worth, I am using G-05 in my 1966 Mopar 440, also with an all-aluminum radiator. 2 years so far, and absolutely ZERO problems. I personally believe that G-05 is by far the safest coolant out there right now, all things considered. Even if you have to order the coolant and wait a few days for it, I think its worth it. See some commentary and a photo of the current state of my radiator in the "G-05 Photo" thread here:
http://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1723205&nt=2&page=1
Whatever you do, I absolutely WOULD NOT use a "universal" coolant like Prestone, nor would I use DexCool or one of its clones.
Congrats on the rebuilt Boss- one of the all-time greats!
