I thought it does something to the gas, like oxygenation for better combustion. How does removing carbon deposits decrease emissions?
The “guaranteed to pass” products are a fuel system cleaner, their goal is to remove the carbon deposits that are causing incomplete combustion. Yes, carbon deposits will raise HC levels in your exhaust. I’m sure plenty of people are familiar with doing a decarbonization or “decoking” on old carburetor engines. I had an old 80’s Chevy that failed the annual emissions test every year, but spray some water mist down the carburetor at a high idle speed helped clean out the combustion chambers and I was able to pass emissions after that.
I have not used the Berrymans version but I have lots of experience with RXP Gas Kicker. Both contain chemicals that promote a hotter, more complete combustion than plain old gasoline. They also contain a cocktail of detergents. The directions generally say to pour the additive in a tank of gas and then run it down to empty, and then refill with plain old gasoline. Once the initial “clean up” tank is used up the combustion chamber is as clean as it’s gonna get, it’s advised to get your emissions test done once you have used up the clean up tank of fuel.
Make no mistake that these emissions cleaners don’t fix worn out or internally damaged engines. Some engines might be beyond hope and won’t pass even with using these products.
Every emissions test law I’ve seen states that the vehicle must be in compliance at the time of testing and nothing more. This is where I think Volkswagen misinterpreted the emissions laws. They programmed some of their vehicles to produce lower emissions when hooked up to emissions testing devices, but once they were no longer in a test environment they went back to being out of compliance.
Again, the law does state “at the time of testing” in most states/counties. Comparing the VW cheating issue to using a “guaranteed to pass” or other emissions reducing additive is a bit of an apples to oranges comparison. With the VW engines they went back to being out of compliance once they were out of testing mode. Who’s to say how long an engine is in compliance once it’s been treated with an emissions reducing additive? Sure, some engines might quickly go back to producing emissions that are out of compliance, but many others might go 5K miles, 10k miles, etc and still be in compliance.
