Originally Posted By: stenerson
Originally Posted By: Oil Changer
I'll never understand the, "Car is more important than the person" mentality. Let the engine tough it out.
Yeah. It's just a machine..It should be serving us..People would actually walk to work in the dead of winter or drive shivering in order to coddle a hunk of metal?
Thus my comment about being soft. I'm not trying to coddle inanimate machines, but putting on an extra layer or a hat and gloves is no big deal, versus an hour of idling a week (per the OP) for a two minute drive. I hate to smell exhaust for the few seconds or a minute if were loading the car under really cold conditions... To spew an hours worth of junk in the air is just incredible when there are better ways to do it. That's not an environmentalist or tree-hugging perspective, but rather the fact that cold engine exhaust stinks and it's rather rude to spew it out for others to have to breathe, when the end result is more hassle/work/cost for the OP.
In the end it's his vehicle, and his mind was made up. If he wanted to be rigorous, he would look at data and find the GPH fuel draw and see how much it was costing, and put that in the mix. And then do a UOA and see specifically how much fuel and water is going in, and set an OCI for that. Were all just speculating without running the experiment. Or you can make the experiment moot by manually clearing windows, wearing another layer, and fixing the water leak and/or cooling system issue that causes the fogging. Even recently when it has been around zero, we haven't had any real issues. And, everyone knows that a car heats up really poorly and inefficiently when not loaded. The amount of waste heat to dump to coolant is FAR lower, like 10-100x lower than if driving with load.
So if the experiment isn't going to be run, change often, perhaps even put something super cheap in like ST, for the winter and then dump it as moisture is observed, often you can see signs of it on the dipstick...
