Originally Posted By: donnyj08
that filter is intersting, its reuasble? so i assume they sell a solvent to clean it with before you re-install it?
that is kind of a nifty idea really.
From their website :
Quote:
Wash the reusable stainless steel filter element in clean solvent, gasoline, kerosene, aerosol carburetor cleaner or any other degreasing agent. You can even finish the cleaning process with some common dish soap and hot water. For stubborn debris, you can use a soft bristle brush to help dislodge particles from the screen. If you have compressed air available, blow air through the filter starting from the inside out, to remove any small particles or cleaning agent from the screen. If you don’t have compressed air, let the element air dry or use aerosol carburetor cleaner or something similar to displace the water. Finally, if you have a spin on model, clean the inside of the filter housing using the same type of cleaner as used on the reusable filter element.
