Originally Posted By: OneEyeJack
On Toyota hybrids I don't think there's an oil pressure light or a temperature light. It's easy to drive off on the electric motor and not kick in the ICE right away. I'm going to take a look at the dash board with I start up next time.
You need to get this problem resolved especially if the car is going to be a "keeper".
It might be worth taking the car to an independent shop where they don't have a lot-boy changing the oil but a real mechanic. It will cost a bit more but you might consider it a good investment. You might be able to survive paying 10 to 20 bucks more once or twice a year. For me it would also be worth getting away from "bulk oil". The industrial hygiene at many dealerships is a risk.
There is oil pressure warnings.
http://www.cars.com/toyota/camry-hybrid/2013/specifications
Part SWITCH ASSY, OIL PRE (L); (L),DENSO; DENSO
TOYOTA Camry Hybrid 2400CC 16-VALVE DOHC EFI, AUTOMATIC
TOYOTA Camry Hybrid 2500CC 16-VALVE DOHC EFI, AUTOMATIC 6-SPEED
TOYOTA Camry Hybrid 2500CC 16-VALVE DOHC EFI, AUTOMATIC 6-SPEED LE
TOYOTA Camry Hybrid 2500CC 16-VALVE DOHC EFI, AUTOMATIC 6-SPEED SE
TOYOTA Camry Hybrid 2500CC 16-VALVE DOHC EFI, AUTOMATIC 6-SPEED XLE
TOYOTA Camry Hybrid 2500CC 16-VALVE DOHC EFI, AUTOMATIC, ATM STEPLESS LE
TOYOTA Camry Hybrid 2500CC 16-VALVE DOHC EFI, AUTOMATIC, ATM STEPLESS XLE
TOYOTA Camry Hybrid 3500CC 24-VALVE DOHC EFI, AUTOMATIC 6-SPEED SE
TOYOTA Camry Hybrid 3500CC 24-VALVE DOHC EFI, AUTOMATIC 6-SPEED XLE
