Just a few thoughts and frustrations from an educated consumer that would like the apples to apples comparison to be valid.
quote:
Originally posted by Filter guy:
Now when Filter Company Z gives out their information on beta ratios or whatever, they are confident based on the ISO test they run.
But if GM wants their filter tested at 8 GPM and Filter Company Z unknowingly runs their tests at 5 GPM this will show different results. Lower flow--better efficiencies. So if GM says their filter is 92% efficient and Filter Company Z says theirs is 94%..maybe filter Company Z's would be 92% or 90% at 8 GPM. However, the spec may actually be a minimum of 65%..which Filter Company Z doesn't know but surely "exceeds".
It is the very nature of the testing proceedure that causes the perceived notion that the consumer is being lied to. It is true that there are testing standards. The very fact that there are excessive variables within the testing proceedure itself make it ripe for manipulation for the sake of monetary gain. The very fact that the automobile manufacuters do not state outright what their parameters are for a given appplication, just makes it more of a cloak and dagger story.
The consumer, just scratching his head...and buying FRAM!
Is it to confusing for you to understand ISO and SAE just set out the test procedure and that is all. It is up to the OEM, or private label customer, or Filter manufacturer to specify the parameters in order to run the test.
It is NOT marketing glitz or "half truths". Regardless of your demented version of filter testing.
Again, the very fact that the testing proceedure has so many variables makes it ripe for manipulation. Just because each manufacturer can state outright and factually that their filter meets certain beta ratios, does not make it helpful to the consumer. Explained another way....us, as the consumer, cannot rightly compare brand x to brand y given the writting on the box due to the excessive variables permitted during testing. Both are factual, but the fact that we, the consumer, don't have all of the facts (ie flow rates, add rates, even the type of "dust" used!!) makes it a "half truth" to us, the consumer, because we cannot compare apples to apples between filter brands for the same application. Don't even go to trying to upsize a filter for an applications and think you can make an educated comparison if you can't for the proper part number between brands. Hence, "half truth" and "marketing glitz" fits from a purely consumer orinted point of view.....because.....in this context ONLY because the entire truth is NOT given for proprietary...read monitary...read trade secretes.
Which brings me back to my point, which i've posted before, unless you know all of the parameters of a test and have the data to compare apples to apples based on the parameters of the test...you don't know the whole picture. And even with Baldiwn showing bits of the test they used, you still don't have the flow rate, Add rate, test termination, etc. Do you?
Understood, again. Just because that is the way the world is, does not mean we, the consumer, have to like it. It also does not mean that the status quo is the best, correct, moral, honorable, upright, way either. Bottom line is...it is all about trade secretes and money. What else can you expect from a capitalist society? Nothing better has come up yet....but that does not mean there are no flaws.
My 0.02 for the month.
