Continue running AmsoilRecently had a 5.3 rebuilt in my truck ran Amsoil break in oil after that switched to Rotella 15w40 with no issues. When should I switch to a conventional oil (have about 1500 miles on the Rotella?)
BITOG likes voodoo, it keeps threads alive.Just drive it and let the engine get to operating temps before womping on the gas pedal hard. No voodoo needed,
all LS motors are roller hydraulic lifters from the factory.I assume it's a roller cam? The Rings seat in about a minute, so it's broken in..
Performance guys don't run the Engine on the Dyno for "X" amount of miles... They start it up and beat on it right away..
Run the oil you want..
They are also the most likely to blow up an engine so not sure it's a good way to judge next practice.I assume it's a roller cam? The Rings seat in about a minute, so it's broken in..
