Anyone else have one? I picked a troybilt up from SLowes a couple days ago to replace my ~7yr old, $50 weedeater 'featherlight' (that's still going): http://www.troybilt.com/webapp/wcs/stores/servlet/product_10001_14102_92353_18652_-1 Lowes sells them for ~$164, plus I had a $10 off coupon. I've only clocked about 30min on her, but it seems like a nice little machine so far. The little MTD 4-stroke has a totally different mellow sound than your typical 2 stroker. Kinda sounds like a little ATV in your hands. Starts easily, power is good, weight feels the same to me as a 2 cycle, vibs the same. Fuel consumption is amazing as is the no stink exhaust & no smoke! The little OHV engine is kinda neat. It has a little ~3oz oil sump with a thread in dipstick/oil fill/oil drain port. It's got a little valve cover up top that removes with one screw so you can check & adjust valve lash. The instructions for that are right in the ops manual. Carb has a manual choke, primer bulb and an idle speed screw. She's got a big'ol muffler that exits out the bottom/rear with a servicable screen spark arrestor. Only thing I wish it had was a clutch. She's direct drive. I guess that's reflected in the reasonable price. I would have loved to get a honda trimmer, but couldn't justify the ~$400+ base price. Oh yeah.. she came with a little 3oz squeeze bottle of MTD 30wt! I'll change out the liquid sprarkles after a cpl uses. I'll probably refill with Shell RT 5w-40. These babies run HOT.
G/luck
Joel
G/luck
Joel
