I just completed the 2d clean cycle of 1452 mi on castrol 5w-30 gtx, planned to go around 1600 but had to replace a blown brakeline so while I had it up on the ramps did the oil change. Oil didn't have the thick sludgy look of the 1st rinse nor were the particles found in the bottom of the drain pan the same size. After the 1st rinse I found particles 1/2 the size of a pencil eraser, this time everything was the size of a grain of sand or smaller. Noticibly absent were the hard abrasive particles from before. The particles this time though visible were not able to be felt between the fingers. Will drain & cut open the filter later this week to see whats in there. Oil consumption before starting arx was 1qt/500 mi, on the 2d rinse I added no oil and lost maybe 1/16" on the dipstick over 1452 mi most of which I believe is from a weeping valve cover so consumption is virtually stopped. During the first clean there were times it would burn a little oil and idle rough at startup, this is not happening on the 2d clean. I have used dino 5w-30 GTX for all phases of the arx treatment. Plans at this time are to run this rinse approx 2000mi then change oil & filter run another dino rinse and then change it over to synthetic for the winter months. If I am still getting much stuff out by then I will add another bottle of arx to the synthetic and run it all winter (about 3000 mi) & drain & do another rinse in the spring. I believe the ARX has made a big difference in the way this car runs.
