They've done it right many times in the past (the hood on my Expedition is aluminum) and the results have generally been excellent save the issue of paint adhesion.
I personally, have not taken a look at one of these new F-150's, but it isn't an issue with Ford being capable of doing it, if there IS an issue, it is one of somebody (or the company) being sloppy and/or lazy. Ford can build a world-class car (like the Ford GT). Whether they CHOOSE to or not, well that's a whole other matter all together.
I think this is probably the problem, Ford cheap out on making body panel correct way(cheaper stamp machine and/or cheaper roll of aluminum sheet), may be they cut corners to save few bucks. But, when they charge upward $50k for fully loaded F150 they should do better job.
If you're paying $50k for this aluminum body F150 and seeing the imperfect body panels what do you think ? I would be pretty upset.
My S2000 has aluminum hood, no obvious problem that I can see, the paint matches with other body parts. I do like the lightness of the aluminum hood, it is much lighter then the steel hood of 2014 Accord. Yes, the Accord hood is a little bigger(probably 10-15%) but I think it probably weights twice as much.
