Originally Posted By: bbhero
I would suggest your analysis is spot on there. 200k miles is probably the expected life of the CVT fluid before it needs to be changed. On the Nissan site a fella had his CVT fluid analyzed by their scan tool.. Car had 56k miles on it. Per scan it said the fluid had 75% of its life left in it. That would put it easily past 200k miles. Heck my lady's Sunfire never had the transmission fluid changed after 214k miles and it was doing fine. One guy on here has 270k on RAV 4 and he never has changed the fluid in it and its been fine. Coolant and oil are far more important to change on a routine schedule than transmission fluid. Been my experience has well.
I disagree...ATF goes bad and needs to be changed...even the supposed lifetime stuff isn't lifetime...though you've mentioned a couple cases where not changing ATF had no negative impact, I have seen many, many cases where not changing out the fluid on a regular basis leads to tranny failure...
