Originally Posted By: bananaman82
So I am about to get my car back this week after a spun bearing at 22000 miles. The dealership and SOA deemed, after 4 months of delegation, that the cause was oil starvation. I disagree. But they are fixing it at no cost to me. The tech told me that Mobil 1 was bad for this specific car. Said the molecules were too small. What oil should I be using? Some have said that Rotella is a good choice despite it's "cheapness." I am just wondering if I need to change the oil I use? This is my dream car and I want to know what I can do to keep it running.
You haven't said how you drive your car?
Are you into clipping the apex of every corner you see?
Do you frequently check the oil level between OCIs and kept the level on maximum?
The reason I ask is that oil starvation is a common cause of a spun bearing and bearing wear generally. If you want to guarantee it doesn't happen again I'd suggest installing an oil pressure gauge so that you can monitor the situation. It will also tell you if the recommended SN 5W-30 is maintaining an adequate operational viscosity at when the oil temp's are high under full boost conditions. It likely is but this way you'll know for sure.
As to what brand of synthetic oil to use, I certainly don't agree with the tech that said not to use M1, nevertheless I would use another name brand they do approve such as Pennzoil or their own Idemitsu made Subaru 5W-30.
