Nothing too exciting. I don't think I posted my previous UOA, so the 7/17 and 10/16 changes are new. As you can probably guess, I forgot to collect a sample during one of my changes (January 2016). The 8,259mi run was actually a blend of 1.5qt AFE, 3qt EP (both 0W20) and .5qt Supertech (5W20).
One thing to note, I did swap out the engine air filter half way through the 7,189mi run, which might account for the silicon (not that I'm worried). As of last year, the Element became our only vehicle, so it gets a lot more short trips when my wife commutes, mixed in with longer weekend trip. I do two oil changes per one oil filter interval. I put in 5qts of M1 0W20 EP back in. I'm trying to extend my intervals, but I usually just change it when time permits.
Code:
2007 Honda Element
Date of Change: 7/17 10/16 4/15 5/14
Miles on Unit: 111,056 103,867 86,415 78,226
Miles on Oil: 7,189 8,259 8,189 6,037
Oil Brand: M1 M1 QS M1
Oil Type: AFE AFE/EP UD AFE
Oil Grade: 0w20 0W20 0W20 0W20
Filter Change: No Yes Yes No
Metals(ppm):
Iron(Fe) 8 6 9 7
Chromium (Cr)
Lead (Pb)
Copper (Cu)
Tin (Sn)
Aluminum (Al) 3 3 4 5
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm):
Silicon (Si) 14 13 10 10
Sodium (Na) 3 4 8 8
Potassium (K)
Additives (ppm):
Magnesium (Mg) 621 571 162 749
Calcium (Ca) 970 1283 1815 979
Barium (Ba)
Phosphorus (P) 576 658 680 633
Zinc (Zn) 635 730 766 738
Molybedenum (Mo) 72 76 218 72
Boron (B) 41 49 10 46
Contaminants:
Water (%)
Coolant No No No No
Physical Tests:
Viscosity (Cst @ 100C) 7.7 7.1 9.3 7.5
Fuel (%)
Soot (%) Infrared 0.4
Physical/Chemical:
Base Number (mgKOH/g) 2.8 3.9 2.6 3.8
Thanks for looking!
Code:
2007 Honda Element
Metals(ppm):
Iron(Fe) 8 6 9 7
Chromium (Cr)
Lead (Pb)
Copper (Cu)
Tin (Sn)
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm):
Sodium (Na) 3 4 8 8
Potassium (K)
Additives (ppm):
Barium (Ba)
Contaminants:
Water (%)
Coolant No No No No
Physical Tests:
Fuel (%)
Physical/Chemical:
Thanks for looking!
