Originally Posted By: userfriendly
OverKill answered my question.
If this was about a 454 BBC instead of a BBF, I would agree with the XW40 blanket recommendations.
The 460 Ford in comparison has larger main & rod journals, in addition to camshaft base-circle and lifter diameter.
The motorhome engine is not likely to produce much power over 4,000 rpm, as a result of all of the above, SAE20 should be capable.
I don't like attaching engine size and GVW to engine oil viscosity.
I advise an HTHS of >=3.5cP, which includes heavy 30's and lighter 40's. I think a 15w-40 would be overkill. These oils also have higher levels of AW additives and are designed for severe service where high load is the norm, and would tolerate elevated oil temperatures far better. They also allow for some fuel dilution, which with a carb, is basically a guarantee.
Yes, the 460 has a better factory lube system than the BBC (similar to how the SBF has a better one than the SBC), or perhaps I should say more forgiving due to some of the design characteristics, like with the 351W, but it was, as I noted, never designed around lubes with an HTHS around the 2.6cP mark (which would be even lower with fuel dilution) and it leaves very little if any reserve to account for that, or for uncontrolled spikes in oil temperature, which will again drive down viscosity.
I have no idea if this engine, in this application, has an oil cooler or not either, so recommendations should, based on that fact, be on the conservative side.
