The 8K run on this oil was submitted to Oil Analyzers Inc, while the 11.9K run was with Blackstone. I'm really surprised at the different values for Lead & Silicon between the two in such a short span between samples (although lead did this between 9-10K on the previous fill as well). I'll probably stick with Blackstone for the next sample at the 8K interval as they suggested. Blackstone is showing the universal average for lead in this engine is 8, how concerned should I be with 59 at probably double the interval?
Make/Model: GM 5.3L V-8
Vehicle: 2004 Chevy Tahoe
Code:
OIL Ams SS 5w30 Ams SS 5w30 Ams SS 5w30 Ams SS 5W30 Ams SS 5w30 Ams SS 5w30 Unknown 5w30
MILES IN USE 11,843 8,231 10,040 9,245 7,002 5,086 3,097
MILES ON UNIT 153,570 149,958 141,600 131,560 129,317 127,401 122,315
SAMPLE TAKEN 8/4/13 5/5/13 9/3/12 11/13/11 9/13/11 7/30/11 4/25/11
MAKE UP OIL 0 .25 0 0 0 0 0
ALUMINUM 5 3 4 3 3 3 3
CHROMIUM 1 0 1 1 0 0 1
IRON 25 15 18 16 11 12 19
COPPER 20 16 21 18 16 14 16
LEAD 59 13 48 16 10 7 14
TIN 1 0 5 0 1 2 0
MOLYBDENUM 143 134 140 149 130 146 18
NICKEL 1 0 1 1 0 0 1
MANGANESE 1 0 1 1 1 1 1
SILVER 0 0 0 0 0 0 0
TITANIUM 0 0 0 1 1 1 6
POTASSIUM 3 3 5 0 2 4 0
BORON 50 62 48 52 65 104 8
SILICON 40 26 38 46 38 33 30
SODIUM 18 14 26 67 61 57 212
CALCIUM 3404 3258 3252 3588 3270 3332 1694
MAGNESIUM 15 14 14 15 14 15 12
PHOSPHORUS 640 637 535 733 750 756 667
ZINC 726 715 616 840 932 958 806
BARIUM 0 0 0 0 0 0 0
CADMIUM 0
VANADIUM 0
ANTIMONY 0
LITHIUM 0
SUS @ 210F 65.3 62.1 62.3 59.1 61.4 57.3
Visc @ 100C 11.68 11.0 10.82 10.86 9.96 10.62 9.45
Flashpoint 440 435 435 435 415 390
Fuel %
Antifreeze % 0.0 ? ? 0.0 0.0 0.0
Water % 0.0
Insolubles % 0.3 0.2 0.3 0.3 0.2 0.4
TBN 1.1 3.36 1.9
Soot %
Oxidation 54
Nitration 15
Blackstone Inc Comments: (11.9K)
We mentioned last time that your bearings might not like longer oil runs, and we're starting to really think that might be the case. Lead increased quite a bit, and 59 ppm is a lot of bearing wear. Iron increased too, but that metal will track with miles on the oil. Not so with lead. The other metals look great. Silicon is still hanging around, but it's staying steady and probably isn't responsible for the extra lead since it's been there all along. The TBN was pretty low at 1.1, and the viscosity is a bit on the thick side. Try 8,000 miles next time to get lead under control.
Oil Analyzers Inc Comments: (8K)
Base number is moderately low. Abrasives (silicon/dirt) are at a minor level. Boron is slightly low for this lubricant. Oil is suitable for continued use. Re-sample in 3,500 miles or 65 hours.
Code:
TIN 1 0 5 0 1 2 0
CADMIUM 0
VANADIUM 0
ANTIMONY 0
LITHIUM 0
Fuel %
Water % 0.0
TBN 1.1 3.36 1.9
Soot %
Oxidation 54
Nitration 15
