Originally Posted By: dishdude
Originally Posted By: panthermike
Originally Posted By: oilboy123
Try the 40 wt weight and see how it does on consumption...
Are you running dino, syn or a blend? If syn you could probably drop down a grade.
Auto-RX might be a good thing to run if warranted. I would like a little econo-box myself.
Yes I think Jay Leno should donate one car a year to a deserving BTOG member in good standing......sheesh he has enough cars for all of us.
He will have a rough retirement, that's for sure.
Well, I'm actually just looking at the car right now for just the reason you stated, economical.
If I do get it, the first thing will be ARX followed probably with High mileage oil.
I heard these are good cars and can last a long time with good maintenance, plus I believe they are the same as the Mazda 121?
I'll update you guys if I join the 40mpg, 23 second quarter mile club
Actually I thought they were Kias? And they are good cars, I think because they are so simple there isn't much to break on them!
Yeah, Kia sounds familiar, I believe Mazda has some part in the car as well.
I'm going to look at the car tonight or tomorrow. It has 192K on the ticker which is high. The guy says it is maintained very well and runs good with A/C and many new parts. I'll check it over, visual sludge through the fill hole, hoses, fluid conditions, etc.
He is asking 800 for it but I think I could probably get it for 500 bucks.
Actually, here is the ad:
Great commuting car, 5 spd. Very reliable- I have been commuting weekly to Sierra Vista since August with this car. Runs great, A/C works. Not the prettiest car, but it is economical. Within the last year the following work has been done: new CV half shafts, front and rear struts, control arm/ball joints, outer tie-rods, rear tires, rebuilt carb, spark plugs and wires, cap and rotor, new belts, master cylinder, valve cover gasket and trans oil replaced. I am sure something is being forgotten... most of the work was preventitive before starting the Sierra Vista commute. 192k on car, 300k common with these engines.
