Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
17 registered members (billt460, dlundblad, ctechbob, avi1777, cjolson140, 2 invisible), 549 guests, and 56 spiders.
Topics286,171
Posts4,903,550
Members67,572
Most Online2,967
Mar 10th, 2019
Wal Mart Blue sealant around drain plug #912309
06/02/07 06:51 AM
06/02/07 06:51 AM
albuquerque, nm
tiger-bailey Offline OP
albuquerque, nm
I purchased a used car that had the oil changes done at Wal Mart. They used some type of blue sealant around the drain plug, and I can't get the drain plug off. Anyone experience this? Thoughts on how to get it loose without breaking something?
TIA.
Rob
Re: Wal Mart Blue sealant around drain plug [Re: tiger-bailey] #912310
06/02/07 07:07 AM
06/02/07 07:07 AM
St. Paul, MN
AcuraTech Offline
AcuraTech  Offline
St. Paul, MN
The plug was probably just over tightened, the waxy stuff they use doesn't have any clamping force. UNLESS the plug was stripped already when they changed the oil and they applied some sort of sealant to keep it from leaking, which also could be what you are seeing.
My recommendation would be to get a half inch ratchet and a six point socket (to prevent the drain plug from rounding), and start yanking away until it gives. Hopefully the oil pan threads aren't stripped.
*The above post is not to be construed as professional advice. For entertainment purposes only.*
Re: Wal Mart Blue sealant around drain plug [Re: AcuraTech] #912311
06/02/07 07:11 AM
06/02/07 07:11 AM
St. Paul, MN
AcuraTech Offline
AcuraTech  Offline
St. Paul, MN
Also remember, leverage is your friend. Longer ratchet = easier to loosen. However, if it takes anything longer than a standard wrench or ratchet to loosen a drain plug, be worried.
Re: Wal Mart Blue sealant around drain plug [Re: AcuraTech] #912312
06/02/07 07:52 AM
06/02/07 07:52 AM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Be prepared to need a new plug and have to chase the threads in the oil pan. It was probably sripped and rather than tell the owner of the car, they used a lot of sealant.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 227K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 201K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 247K miles
Re: Wal Mart Blue sealant around drain plug [Re: 01rangerxl] #912313
06/02/07 09:30 AM
06/02/07 09:30 AM
New Jersey
televascular Offline
New Jersey
It's even possible that they were too cautious and used medium-strength threadlocker on the drain bolt. Kinda the polar opposite of quick lube joints, eh?
It's overkill, but maybe that's what the blue stuff is.
'06 Honda Civic Si
Amsoil SSO 0w-30, Synchromesh MTF
Re: Wal Mart Blue sealant around drain plug [Re: televascular] #912314
06/02/07 09:46 AM
06/02/07 09:46 AM
Orillia, Ontario
Squishy Offline
Squishy  Offline
Orillia, Ontario
All the Wal-Marts around here use that blue stuff. It's not sealant in the traditional sense, nor is it threadlocker - it's a tamper seal. They put it on so that they can tell if you or another shop messed with the drain plug after they changed the oil. I guess they found out that a lot of people were blaming them for an oil change faux pas after a little shop screwed up, since they (Wal-Mart) have bigger and deeper pockets.
As for the overtightened plug...yeah, they'll do that. Breaker bar then a chaser should do the trick. If it's really bad, you might need an oversized plug.
Re: Wal Mart Blue sealant around drain plug [Re: Squishy] #912315
06/02/07 09:48 AM
06/02/07 09:48 AM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Ahhhh...the mystery is solved. That is pretty smart on Wal-Mart's part...now if they could do something about the people who return used oil in new oil bottles.
Re: Wal Mart Blue sealant around drain plug [Re: 01rangerxl] #912316
06/02/07 09:50 AM
06/02/07 09:50 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
wal-mart isnt the only place that does it. when i worked at sears we were required to torque drain plugs to spec with a new seal, and apply the tamper-seal.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Wal Mart Blue sealant around drain plug [Re: bdcardinal] #912317
06/02/07 10:03 AM
06/02/07 10:03 AM
Grand Rapids, MI
ThirdeYe Offline
ThirdeYe  Offline
Grand Rapids, MI
They did it at a car dealership here too on my car before I purchased it. I always wondered what it was, thanks for the explanation It didn't leak so I didn't think it was a sealant masking anything.
07 Honda Accord - 608k - Havoline High Mileage 5W-20/Purolator Synthetic PSL14610
98 Camaro Z28 (Bright Purple Metallic, 1 of 104) - 122k - QS Defy 5w30/AC Delco PF46
Re: Wal Mart Blue sealant around drain plug [Re: ThirdeYe] #912318
06/02/07 10:07 AM
06/02/07 10:07 AM
Orillia, Ontario
Squishy Offline
Squishy  Offline
Orillia, Ontario
Hmm, another thought - if the tamper seal is still intact, would it be possible to take it to Wal-Mart and make them deal with it? After all, they provided the proof themselves of who is really at fault.
Re: Wal Mart Blue sealant around drain plug [Re: Squishy] #912319
06/02/07 10:14 AM
06/02/07 10:14 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
they arent the only ones that use blue. and yes you can use it against them, however if they are like most other shops, an oil change is only warrentied for 90 days, if at all. espeically if you let an oil change interval go for a long time. we had someone claim that their motor froze and it was our fault since we worked on it last. it still had a perfect tamper seal from us, unfortunately the oil change was done 2 years prior.
Re: Wal Mart Blue sealant around drain plug [Re: bdcardinal] #912320
06/02/07 10:25 AM
06/02/07 10:25 AM
Orillia, Ontario
Squishy Offline
Squishy  Offline
Orillia, Ontario
Yeah, but if he has the receipt from the previous owner and goes at 12:20 while the service manager is out to lunch, maybe he could harass one of those high school lube kids into dealing with it. Admission of guilt from the lube guy and some belligerent rambling when the service manager gets back might net you some results. I doubt a calm man-to-man talk would get you anywhere at Wal-Mart; a dealership or father-son garage, maybe.
Re: Wal Mart Blue sealant around drain plug [Re: Squishy] #912321
06/02/07 07:14 PM
06/02/07 07:14 PM
Vancouver, BC
alanu Offline
alanu  Offline
Vancouver, BC
Lube shops tend to use a sealant or a rattle can of primer or a thick coat of paint to prevent a drain bolt from loosening off. Kind of a safe precaution measure for the inadequate experience from the kid that changes the oil.
More than likely a cheap plastic gasket was used too. They are the worst gaskets available!!! Why are they used??? CHEAP! CHEAP! CHEAP! Odd thing is when a drain plug falls out an engine costs alot more than a 5 cents plastic gasket.
Re: Wal Mart Blue sealant around drain plug [Re: alanu] #912322
06/02/07 08:06 PM
06/02/07 08:06 PM
Grand Rapids, MI
ThirdeYe Offline
ThirdeYe  Offline
Grand Rapids, MI
I had a plastic drain washer/gasket put on by a local dealership here, and when I went to drain the oil, the plug came off simply by using my fingers, that's how loose it was. I don't know if it was because of the washer, but my oil pan was wet because of it too. -smiles happily at my stash of 60 OEM Honda drain plug washers- Much better
Re: Wal Mart Blue sealant around drain plug [Re: ThirdeYe] #912323
06/02/07 08:52 PM
06/02/07 08:52 PM
MN
T-Keith Offline
T-Keith  Offline
MN
I worked at a Wal-mart TLE back in college. First, Squishy is correct, it is just to tell if someone worked on it since the oil was changed. It also serves as a visual check that the plug has been tightened.
Secondly, alanu, believe it or not, but the plugs and gaskets Wal-mart got were the best quality and the closest to OEM of ANY lube shop I've seen. You'll have a hard time finding such a good selection at an auto parts store. In fact all of the auto parts store ones I've seen are generic junk. Not only that, they are the only shop that I know of that doesn't use oversize plugs(self tapping plugs that destroy your oil pan) Now that doesn't mean that some untrained employee won't use the wrong gasket on your car.
Bottom line is you will have bad service at any shop, including the dealer, so do it yourself.
'14 Volt
'11 Enclave
