Could it hurt any to try a sea foam soak (start with warm engine, let sit overnight with plugs loosely installed to minimize eveaporation), with also trying some through a vac line? It seems that a piston soak by pouring some through the spark plug hole just cleans the piston tops, but I'd figure some to also seep past the rings - also be sure to turn the engine with the starter prior to reinstalling the plugs to get most of the liquid out to help prevent hydrolocking. be mindful of spark emissions from the distributor while doing this (ground a plug that's attached to the min high-tension lead from the coil if the charge must be dumped - i think I remember someone saying that some newer electronic units require discharge to prevent damage..don't understand quite why unless it's such a high voltage it could jump somewhere from around the coil - seen this with a different step-up transformer I've used in experiments).
Like others have mentioned, you may want to also try running one weight up, or perhaps a straight weight if it seems to blow-by the most when going through the warm-up cycle.
A friend of mine had a situation where oil fouled his tractor's air filter after I did an oil and filter change - appearently the oil level as read on the dipstick shouldn't be above the half-way mark in the mettering area. Has the fill level changed at all since before this became appearent?
