320K mileage - recommendations?
by joshuawesl - 05/30/20 12:36 PM
ISO Sprint sim
by pkunk - 05/30/20 11:44 AM
2001 Mazda Miata, timing belt
by frankbee3 - 05/30/20 11:15 AM
3M tape removal
by loneryder - 05/30/20 10:31 AM
Which string trimmer
by DeafBrad - 05/30/20 10:26 AM
Conventional Oil Benefits
by Bogdon - 05/30/20 07:38 AM
I'm finally retired!
by grampi - 05/30/20 07:20 AM
2020 Equinox 1.5t
by IMPALA08 - 05/30/20 07:05 AM
Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
RedMan542, bdubb, TreePointer, PierreS, GDR
71572 Registered Users
97 registered members (928, 2004tdigls, 4WD, alchargo, aquariuscsm, 10 invisible), 2,730 guests, and 46 spiders.
Topics306,044
Posts5,285,544
Members71,572
Synthetic oil ok too use w/bar leaks oil leak stop? #5394789 04/05/20 05:59 PM
Z
ziggy Offline OP
Z
Hi all! Car has a oil pan leak. 98 Buick lesabre limited.got it Craigslist 2 years ago,had so many problems,I've since fixed. Had 111,000 miles or so,on it. Now 124,000. So!last year I put Castro synthetic in it,edge, 0w30. Wanted too try different. Leak developed from oil filter area.oil pan gasket,facing filter side.it's not a bad leak at all. Put a large red bottle of gumout oil stop leak I bought a while back!it wirked,mostly!still drips a little.
Can,bars leak stop leak,for oil,he used,with synthetic oil? I have quarts,of Pennzoil ultra I bought on clearance autozone, 2013 stockpiled.I do know,it has a lot of calcium in it. That means,clean. I used mobil1 in a 95 neon some 15 years ago. It cleaned so well,my dear main had to be replaced on that car.but puddle of fresh oil under the car.
So!with my lesabre, I know not too use synthetic.unless,it has stop leak in it,like high mileage have conditioners. Is it risky?ok? Too use the bars leak with Pennzoil ultra? Would the oil basically clean,the bars leak won't work?
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5394822 04/05/20 06:40 PM
L
Lolvoguy Offline
L
you could, but why bother?!
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5394847 04/05/20 07:00 PM
caprice_2nv Online Content
Online Content
I would use what you have. I don't know about bars leak but if it's a minor leak why worry about it? It will likely leak the same with conventional now. I'd rather run good oil and not worry about stop leak unless it was a major leak.
The leak probably has more to do with the vehicle sitting a lot before you bought it. Age is hard on those gaskets. As long as you don't have intake gasket leaks than I wouldn't worry about that engine.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5394850 04/05/20 07:07 PM
R
Rolla07 Offline
R
Just run an HM. No point bothering with syn. I just dont see the point.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5394858 04/05/20 07:15 PM
Z
ziggy Offline OP
Z
Figured, ice use my stash as a yearly flush,before an oil change.but,why waste can good oil like that.I do know,it will leak,without a sea?er/rejuvinator. Pennzoil ultra cleans so good,it has a lot of calcium in it.alot...would that calcium , make the bars leak basicaly,pointless too use? Or,would,the bars leak,infact,seal up the oil pan with a cleaning oil like Pennzoil ultra?
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5394916 04/05/20 08:26 PM
danez_yoda Offline
https://www.amazon.com/ATP-AT-205-Re-Seal-Stops-Bottle/dp/B000NVW1LM
many youtube videos show this works better than Bars stopleak.
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5395289 04/06/20 09:08 AM
M
Mad_Hatter Offline
M
The oil and the stop leak will not conflict, you can read this on Bar's website. Whether or not it'll address your problemo is a different discussion but if you have the $5 to burn it's not gonna hurt anything. Keep in mind it could take several hundred miles for a stop leak to have an effect. You can also try a HiMi formula oil for a couple of drain intervals to see if that improves things. If not, the seal is likely too far gone for any stop leak. Also if your pan gasket is fibre, no stop leak will help with that. You need to replace it.
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5396328 04/07/20 10:43 AM
M
Miller88 Offline
M
How big of a leak are we talking? If it's just a few drops here and there or a seeping pan, I wouldn't even bother.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5396660 04/07/20 05:23 PM
CT8 Offline
Is the pan sealed with RTV? [silicone sealant] ?
2015 F150 2.7
2018 F350 6.2
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5397970 04/09/20 12:35 AM
Z
ziggy Offline OP
Z
I think...the oil pan gasket is shot.I checked oil dipstick other day,it was not full! 4.7 quart engine. I used Castro synthetic 0w30 back in october,last oil change. Have about 2500 miles now.I do know,last oil change,side of filter facing oil pan,had oil on it.that's how I know,gasket not good,oil pan. But,I just a used too low a viscosity oil,and being synthetic,more slippery,it all eventual came out! I poured 4.5 quarts old backline dino 5s30 I got at clearance,Wal-Mart 2004 or so. Car is specd,for 10w30. Book shows 5 a30 is ok,if cold.oil cap shows 10a 30.
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5398004 04/09/20 05:08 AM
PimTac Offline
Looks like the solution is obvious.
Maybe try Castrol instead of that Castro oil you currently are using.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Synthetic oil ok too use w/bar leaks oil leak stop? [Re: ziggy] #5403501 04/15/20 12:11 AM
T
talest Offline
T
Synthetic oil may be aggravating the leak stopping. As far as a plasticizer stop leak.. tried Blue Devil Oil Stop Leak? Or White Shepherd?
There IS Valvoline Maxlife Full Synthetic (which I have used, and like to use) however.. any conventional or maybe even Pennzoil High Mileage (or again.. MaxLife) may work well.
In trying HM oils.. I have found MaxLife to be the most effective. I sometimes try something else, to give it a shot and see how it does.
Or, just J-B Weld the hole in the pan. Works well on oil....
