Originally Posted by Anthony
With your budget the Tundra would be a good choice. Also with what you plan to do with it the 11-14 F150 5.0 would be a go choice as well. 1st gen Coyote is reliable with an excellent, and stout 6 speed backing it up. The 360hp, and 380 ft lbs will haul your trailer easily.
The Tundra you listed will be a stronger puller with its 381hp, and 401 ft lbs.
You can't base everything off rated power/torque....A 3.92:1 geared Ram with a ZF8HP would likely tow better than those two.
