Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Ghosty, zmann96, yetti96, weekendwally, Bugsbrewery
71601 Registered Users
102 registered members (AandPDan, 1911CHAMPION, 830Lee, 4WD, 53' Stude, 13 invisible), 1,908 guests, and 37 spiders.
Topics306,109
Posts5,287,649
Members71,601
Page 8 of 8 1 7 8
Re: Engines that actually require Thick or Thin oil? [Re: camrydriver111] #5371436 03/09/20 09:34 AM
CT8 Online Content
Online Content
Dr Hass turns over his cars frequently.
2015 F150 2.7
2018 F350 6.2
Re: Engines that actually require Thick or Thin oil? [Re: rooflessVW] #5371438 03/09/20 09:36 AM
CT8 Online Content
Online Content
Originally Posted by rooflessVW
Supposedly the 5.7 Hemi "needs" a -20.
I prefer my oils to end with a -40 or -50.
Needs?
2015 F150 2.7
2018 F350 6.2
Re: Engines that actually require Thick or Thin oil? [Re: camrydriver111] #5371443 03/09/20 09:37 AM
K
kschachn Offline
K
You could have an oil that has an insufficient MOFT (too thin) but you can't really have an oil that is too thick, correct? At least at operating temperature and within those oils readily obtainable. An oil can be too thick to pump at cold temperatures but how could an oil be so thick at operating temperature to cause damage?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Engines that actually require Thick or Thin oil? [Re: kschachn] #5371457 03/09/20 09:47 AM
4WD Online Confused
Online Confused
Won’t “too thick” just get hotter in a bearing and the heat will thin it out anyway ?
Other than that, parasitic loss etc … but that’s not metal damage … just wasted fuel/money …
Only other thing that comes to mind is distribution (each flowpath in the lubrication system) or the impingement from an oil jet can vary with viscosity … “sling” … but all these things are likely very minor …
Re: Engines that actually require Thick or Thin oil? [Re: camrydriver111] #5371804 03/09/20 06:24 PM
SR5 Offline
And of course a 5W20 at 10F is much thicker than a 10W30 at 200F, so if thickness was an issue, oil temperature would be the big problem. But it isn’t an issue if you are within the cold starting design of the oil, where it can be effectively pumped. (0F for a 10Wx)
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Engines that actually require Thick or Thin oil? [Re: camrydriver111] #5372029 03/09/20 11:36 PM
L
Loobit Offline
L
It's "one size fits all" for engines nowadays. Bearing clearances are very precise in all new engines, and overhead cam engines like lower "W" rated oil since oil needs to flow to the cams on top of the engine quicker in a cold start. 5w-30 has been the go-to for this. Now it's more like 5w-20 and 0w-20 in normal driving conditions. I'd bump it to 5w-30 if towing or driving up mountains all the time or something. 0w-30 and 0w-40 are in more expensive overhead cam engines with turbos.
Older pushrod engines without VVT or cylinder deactivation don't care much about thick oil unless it's freezing outside. There are less parts that oil needs to flow to. Go ahead and dump 10w-30 or thicker like 15w-40 in an engine like an LS1 as long as it's in summer. They may actually sound smoother if they are very high in miles. Pushrods can still benefit from 5w-30 or 0w-30 in winter.
Re: Engines that actually require Thick or Thin oil? [Re: Loobit] #5372142 03/10/20 07:00 AM
Bryanccfshr Offline
“overhead cam engines like lower "W" rated oil since oil needs to flow to the cams on top of the engine quicker in a cold start.”
There is no quicker, it either pumps or it doesn’t. The same volume of oil per pump turn is moved, pushing oil down the galleys at the same rate, this morning at 52 f my Tacoma will not know the difference between a 0w20 and the 10w30 in the sump. The only way the oil will slow down is if the oil is at a temperature below its pumping viscosity.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Page 8 of 8 1 7 8
