Forums Migration
Please read this thread
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Swimming Pool Chlorination
by Al - 07/08/20 02:30 PM
Purolator Boss
by RazorsEdge - 07/08/20 02:01 PM
B2300 frame repair.
by simple_gifts - 07/08/20 01:48 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
92 registered members (antonmnster, 07hemi, AdamZ, alcyon, 4WD, 11 invisible), 1,478 guests, and 42 spiders.
Topics307,624
Posts5,314,435
Members71,888
Which Cleaner for Old 6-cyl? #5368934 03/06/20 12:27 PM
G
Greg L Offline OP
G
My old carb on my 1951 GMC, with 270 motor and WA-1 Carter, seems to be getting a bit more bogged down these days. I haven't cleaned it since I bought the rebuilt carb 7 years ago.
Question: what gas additive should I use to clean the fuel line and the carb intake/jets?
Or is regular Chevron gas enough?
GL
1951 GMC 1/2 Ton 270ci
2008 Jeep Compass 2.4
2013 Toyota Prius 1.8
2011 Dodge Ram 1500, 5.7 Hemi
Re: Which Cleaner for Old 6-cyl? [Re: Greg L] #5368944 03/06/20 12:38 PM
J
JeffKeryk Online Content
Online Content
J
In our old trucks, we used to undo the fuel line at the tank and carb and blow air through. All kinds of junk came out.
Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Which Cleaner for Old 6-cyl? [Re: Greg L] #5368956 03/06/20 12:57 PM
chemman Offline
I would pour a can or two of Berryman B-12 into your gas tank and drive it clean. I add it to my riding and push lawn mowers and do not have any fuel related problems. I also ran B-12 in a 1980 Chevy Impala with a Quadrajet in the late 1990s to mid 2000s with great results as well.
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: Which Cleaner for Old 6-cyl? [Re: Greg L] #5368957 03/06/20 12:57 PM
9
97prizm Offline
9
Years ago i helped trackside at scca races. One of the cars had a ca4b and sure enough my boss pulled the jets and cleaned them. This also helped
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Which Cleaner for Old 6-cyl? [Re: Greg L] #5368967 03/06/20 01:26 PM
Cujet Offline
At the very least, it's a good idea to use carb clean to simply clean the venturi, throttle plate and choke. Varnish can build up and change the air/fuel mixture.
You can always try different types of fuel additives. But I agree, Berryman B12 is pretty capable stuff.
Re: Which Cleaner for Old 6-cyl? [Re: Greg L] #5368969 03/06/20 01:28 PM
G
Greg L Offline OP
G
Thanks!
Re: Which Cleaner for Old 6-cyl? [Re: Greg L] #5369039 03/06/20 03:02 PM
Propflux01 Offline
Techron
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Which Cleaner for Old 6-cyl? [Re: Greg L] #5369223 03/06/20 06:32 PM
CT8 Offline
Filter? carb loose or gasket leaking.
2015 F150 2.7
2018 F350 6.2
Re: Which Cleaner for Old 6-cyl? [Re: chemman] #5369302 03/06/20 08:11 PM
R
Rickey Offline
R
This !!!!
Re: Which Cleaner for Old 6-cyl? [Re: Greg L] #5369423 03/06/20 10:20 PM
Dinoburner Offline
While the Carter is a reliable carb the Rochester was more fuel efficient. The Carter is easier to rebuild tho and that would be what I would do. The Berryman and the chevron are both good.with the Berryman being my choice carbs.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
