wemay
Site Donor 2023
http://www.chemcorp.co.uk/news/i/37...w-viscosity-high-protection-engine-oil-/
Mobil 1 ESP x2 0W-20 has been designed to deliver the following performance benefits:
•            Active cleaning agents: Helps to prevent the build-up of harmful deposits to  Â
             help provide outstanding engine cleanliness and sludge control
•            Outstanding thermal and oxidation stability: Helps to reduce oil aging allowing
             extended drain interval protection
•            Enhanced frictional properties: Can help with up to 4% fuel economy
             improvement versus Mobil 1 ESP Formula 5W-301
•            Excellent low temperature capabilities: Quick cold weather performance to
             help provide fast protection at start-up
•            Outstanding high temperature capabilities: Provides outstanding high
              temperature protection over the entire oil drain interval
•            Wear protection: Provides outstanding wear protection over the full oil drain
              interval
•            Mobil 1™ ESP x2 0W-20 is the first low viscosity oil product that can help
              provide fuel economy benefits without comprising the performance and
              durability of petrol and diesel-powered engines
•            New product meets the rigorous performance requirements of manufacturers,
              such as Volkswagen Group, Jaguar Land Rover and Porsche
•            The lubrication standards set by these OEMs far exceed the requirements set
              for previous 0W-20 products, and were previously only achievable with higher-
              viscosity products
•            Innovative new formulation can help offer advanced engine protection and fuel
              efficiency gains of up to 4%
              interval
              viscosity products
