Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
Daytona 500 engine related question
by OilUzer - 02/16/20 07:37 PM
2006 Subaru Forester 2.5 NA
by 762fermeandyou - 02/16/20 07:29 PM
DIY Paintless Dent Removal....
by dblshock - 02/16/20 07:17 PM
Bad sports teams
by 53' Stude - 02/16/20 06:42 PM
Valvoline 20W-50 Baja 1000 Race oil
by kstanf150 - 02/16/20 06:21 PM
How to stand on the roof of a Saturn Vue?
by atikovi - 02/16/20 06:09 PM
Spliceline wire connectors
by Donald - 02/16/20 05:22 PM
Found a few clearance oils at AZ today
by PantherFan88 - 02/16/20 04:55 PM
NASCAR electric
by CourierDriver - 02/16/20 04:52 PM
Valvoline Modern Engine vs Regular synthetic?
by PantherFan88 - 02/16/20 04:50 PM
Converting 1970 396 to Fuel Injection
by 007 - 02/16/20 04:47 PM
2016 frontier.
by red7404 - 02/16/20 04:34 PM
Ruger .22 SA - not a good show
by JHZR2 - 02/16/20 03:48 PM
engine maintenance Jaguar
by jssaab - 02/16/20 03:02 PM
New TSC clearance
by Greg L - 02/16/20 02:58 PM
Castrol Edge 5w20 and 5w30 Costco
by nlife - 02/16/20 02:41 PM
Generator Hour Meter
by spasm3 - 02/16/20 01:44 PM
Clifton, JohnEmm, Fastvette, Geode, rob1715
70716 Registered Users
114 registered members (5AcresAndAFool, ABerns, 53' Stude, 762fermeandyou, 2009Caraman, 13 invisible), 2,240 guests, and 49 spiders.
Topics301,539
Posts5,197,534
Members70,716
Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles #5329786 01/22/20 06:50 PM
discountdon Offline OP
so I got two 12 oz. bottles from Autozone, currently on sale for $8.49 BOGO until 02/20/2020...
Regane® Complete Fuel System Cleaner
12 oz. Part No: 510106 - treats up to 19 gallons
then I noticed that their
6 oz. Part No: 800001364 - treats up to 21 gallons
why the convoluted concentrations to begin with???
crzy
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to driveline immortality
planned obsolescence WWFis traitorous to the world
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: discountdon] #5329917 01/22/20 09:47 PM
J
Jackson_Slugger Offline
J
I noticed this myself. IDK, but I thought 12-oz. Regane bottles were an Autozone only thing, so not sure I trust the dosing...
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: Jackson_Slugger] #5329926 01/22/20 10:00 PM
I emailed them, we'll see what they say...
Also it seems they've discontinued the 20-oz. Gumout One-N-Done offering completely, I still have a bottle - it treats up to 25 gallons and supposedly you use it once a year or every 10-15,000 miles!
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: discountdon] #5330017 01/23/20 05:06 AM
T
Triple_Se7en Offline
T
crzy
Curious! Does the smaller bottle say Concentrated and the bigger bottle doesn't?
1-2 BITOGERs harrassing you? Use the Ignore User feature.
Keep your Pistons Clean
2019 Hyundai Santa Fe 2.4 GDI / 2020 Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filter
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: Triple_Se7en] #5330043 01/23/20 06:54 AM
nope...
https://gumout.com/fuel-additives/regane-complete-fuel-system-cleaner-6oz/
https://gumout.com/fuel-additives/regane-complete-fuel-system-cleaner-12oz/
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: discountdon] #5330090 01/23/20 08:04 AM
Davejam Offline
If its just more dilute its not really a good deal...since the 6oz can be had for about $4 regularly and less than that if you find a deal.
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: Davejam] #5330902 01/24/20 08:44 AM
M
Mad_Hatter Offline
M
The amount of pea in either is calculated by X% by weight. So unless the larger bottle has a significantly less %, it will have more pea in it.
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: Mad_Hatter] #5331004 01/24/20 11:03 AM
Davejam Offline
It suggests a similar treat rate per bottle which translates to drastically different treat rate per oz., and the MSDS lists a range of 10-30% by weight of PEA.
So, my reasoning says that the larger bottle is more dilute by half or more which is simply a marketing ploy to make you think your getting a better product/deal...But your not.
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: Davejam] #5331235 01/24/20 04:36 PM
M
Mad_Hatter Offline
M
Your "reasoning" is wrong. Assuming that both bottles have the same %, the larger/heavier of the two bottles will have more pea. It's the volume of gas you're adding it to that dilutes it, not the product. If you do an apples to apples on the amt of gas being treated, since the label says "treats up to", the larger of the two bottles will introduce more pea than the smaller.
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: discountdon] #5335231 01/29/20 08:07 AM
Davejam Offline
I am not assuming they are the same %. I am saying they are different based on the treat rate.
If it were the same % then the larger bottle would be able to treat 35gal, much like the 10oz bottle of Gumout all-in-one.
If it were so they would definitely claim that.
What makes you think the larger bottle must contain the same %?
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: discountdon] #5335313 01/29/20 09:34 AM
B
buddylpal Offline
B
I’ve noticed this with Techron too. The smaller bottle is now 10oz and treats 15gal. The predecessor was a 12oz bottle that treated 12gal. The 20oz bottle still treats 20gal and the 32oz bottle still treats 32gal. The smaller bottle appears to be more concentrated based off dosage instructions. All the Techron used to be 1oz per 1gal of fuel.
A couple GM's and a Hyundai.
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: discountdon] #5335377 01/29/20 11:19 AM
P
painfx Offline
P
For techron I always use the big bottle.
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: Davejam] #5335633 01/29/20 03:55 PM
Gumout uses a single SDS for (3) SKU's: # 510014, # 800001364, #51010, all concentrations can be covered by their stated 'range':
https://3enoro1q5ve12ubndv13jkpk-wp...-Regane-Complete-Fuel-System-Cleaner.pdf
I've received no response from Gumout/ITW Global Brands after 7 days since two separate contacts... I also compared colors between the lower and higher concentrations, they look are dyed visually the same.
Just more fillers on the dilute version I suppose...
cylon
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: discountdon] #5336689 01/30/20 06:15 PM
Davejam Offline
Thanks for the update.
I'm guessing based on treat rate the 6oz bottle is around 25-28%PEA, while the 12oz bottle is 12-14%
Re: Gumout Regane Complete Fuel System Cleaner w/ PEA in 12 oz. & 6 oz. Bottles [Re: discountdon] #5337742 01/31/20 09:13 PM
B
blufeb95 Online Content
Online Content
B
If anyone here's looking for cheap Gumout products, Wal-Mart and Amazon have Multi System tune up which is 16oz and approx 9.63% PEA for only $3.51 a can right now, Walmart also has a 12 pack bundle for 39.60 ($3.30/ea)
