Originally Posted by MolaKule
Well, I don't know what happened to your last post (apologize) as I attempted to quote it but my question was:
Understand but what is that centrifugal-looking element at the front of the core assembly. Is that a diffuser?
The engine has a 4 foot fan, with blades designed to shed ice outward via a bit of reverse twist at the root. The core engine draws air from the fan's blade root area. So I think what you are looking at is simply the layout and ducting of the engine. I'm hoping to find a better picture.
I took a bunch of pictures when at RR Canada for the overhauls. I'll look for them.
BR725 cutaway. Same engine, one extra low pressure turbine.
Possibly of interest, but these engines are really quite different (in design and materials) from high bypass airliner engines. They are medium bypass engines, with long engine cowls and high discharge pressures/velocities. The goal is to provide adequate thrust at very high altitudes and speeds. This is done by increasing nozzle discharge temperature, thereby raising the speed of sound at the nozzle and increasing the discharge speed. Done by mixing core engine exhaust with fan air. The Gulfstream G650 we had could cruise at M .92 at FL470. That was about the limit of it's performance (in normal mode) , with regard to altitude and speed, but what a nice limit. FL510 was a bit slower. Of course, it had enough thrust below FL470 to easily run into and over MMO (max mach operating number, airframe speed limit) .
With regard to the "normal mode" I mentioned above, the engine can make more thrust in "alternate" mode. Normal mode is set, in part, by the airframe manufacturer to prevent overspeed/overthrust/airframe stress and to allow rated thrust under all published conditions. Alternate mode is a mode of operation limited only by engine RPM and Temperatures.
