New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
Am I killing my transmission?
by Avery4 - 01/28/20 08:52 AM
BorgWarner to buy Delphi in $3.3B deal
by wemay - 01/28/20 08:37 AM
COP's which brand
by Eric Smith - 01/28/20 07:56 AM
$150 off Bridgestone tires
by D1dad - 01/28/20 06:26 AM
Helicopter
by Exhaustgases - 01/28/20 01:25 AM
Shell Helix Ultra 5W-30
by SR5 - 01/28/20 12:30 AM
Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
SandeepG, IslandOil, 01VFR, M10, H20ham
70545 Registered Users
95 registered members (67ZL1, 1WildPig, 53' Stude, 1978elcamino, 28oz, 2010Civic, 11 invisible), 3,709 guests, and 23 spiders.
Topics300,667
Posts5,180,662
Members70,545
is on car rotor cutting the best method? #5295560 12/16/19 12:37 AM
W
WhyMe Offline OP
W
watched a few vids about on car rotor cutting machines. they tout that they do a better job as they compensate for total run out of the whole assembly. seems to be very important for FWD cars especially Hondas.
So are these machines really the best for machining rotors? do they prevent or lessen the chance of pulsatiing pedal and wheel shake?
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295561 12/16/19 12:43 AM
The Critic Offline
For most OEM's, machining a rotor on-car is the only method that is allowed for any warranty claims.
It is possible to match the results of an on-car lathe if you use a bench lathe that is in great condition (with a knowledgeable operator), but these are far and few.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295578 12/16/19 01:39 AM
M
Mainia Offline
M
Up in the upper Midwest rust belt, rotor cutting is so 1980s, you just get new rotors. Since cutting them cost almost as much as new ones.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295604 12/16/19 03:16 AM
G
GMBoy Offline
G
New rotors. Turning them isn't worth the hassle.
Re: is on car rotor cutting the best method? [Re: GMBoy] #5295606 12/16/19 03:49 AM
4WD Offline
And in many cases you can upgrade to more corrosion resistant discs
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295635 12/16/19 05:56 AM
Sayjac Offline
I've had rotors turned off the vehicle on Accord and Civic several times, never an issue. I do prefer using a shop that finishes with a non directional finish or post lathe surfacing over a directional finish. I had it done for brake pulsation and it did work. ymmv
That said, I suppose if one is willing to pay the cost difference for having an on the car turning done, have at it. I'd buy new rotors before I'd do that.
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295654 12/16/19 06:38 AM
G
Gebo Offline
G
I have never had good luck turning my rotors. Of course, I probably made bad choices in where I took my rotors to be turned.
I only buy new OEM rotors and OEM pads now.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
PP HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295668 12/16/19 06:48 AM
Donald Online Content
Online Content
Many years ago some 4WD vehicles (Ford Ranger) had the rotor integrated into the hub and you had to take apart the entire hub to remove the rotor. In that case on-vehicle rotor machines were used. Today people just get new rotors.
2015 Ford F-250 w/Powerstroke
Re: is on car rotor cutting the best method? [Re: Mainia] #5295685 12/16/19 07:04 AM
A
atikovi Offline
A
Not when a new replacement rotor is $500-$1,000.
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295696 12/16/19 07:18 AM
sdowney717 Offline
I have only ever bought a set of rotors and that was for ones that were rusted on. I had to cut and split them off with a chisel. I have even taken rotors off and ground them by hand on my concrete driveway to remove a edge ridge. None of the rotors out of some 10 cars have ever caused brake problems. I buy lifetime brake pads and DIY.
They also don't shake, but I do have one Ford Contour that does shake a tiny bit, but they are not warped, they have some hard spots on the metal surface.
I use rotors others would cringe at as they are not perfect and smooth and swear they must be ground and the car stops fine with new brake pads. Take that car into a mechanics shop and they will tell you new rotors or turn them. the car business will kill you with money costs unless you know what your about, and I have wrenched for 40 years and used to be a mechanic at a Chevy dealer, yeah we would make the customer buy all sorts of new stuff even if the original parts were still ok.
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295699 12/16/19 07:19 AM
Cujet Offline
It's good to know that if a rotor warps when hot, it's going to warp when hot after it's been turned.
One thought is that the recycled metals are distributed unevenly in the disk. Another is uneven cooling, the metals in one location were "tempered" by a red-hot stop, then keeping the pads clamped on that location while the rest of the rotor slowly cools.
Regardless of why it happens, "IF" you experience heat related warping, replace the rotor.
Re: is on car rotor cutting the best method? [Re: Cujet] #5295717 12/16/19 07:39 AM
sdowney717 Offline
https://www.onallcylinders.com/2017/05/19/6-biggest-brake-rotor-myths-debunked/
Rotors do not warp. I am a mechanic. It is a myth. I did turn one badly once and since it was not true it pulsated and had to get re-turned.
https://www.brakeandfrontend.com/warped-rotors-myth/
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3043065/1
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3895543/all/Brakes_Rotors_DON'T_WARP__-__A
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295723 12/16/19 07:50 AM
R
ragtoplvr Online Content
Online Content
R
Replace rotors. Here, I mask them off and paint them. Not much snow here in southern joplin
Rod
Re: is on car rotor cutting the best method? [Re: WhyMe] #5295748 12/16/19 08:19 AM
ls1mike Offline
I have not had rotors turned since my 1988 Dodge Daytona.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: is on car rotor cutting the best method? [Re: sdowney717] #5295916 12/16/19 11:40 AM
U
UncleDave Offline
U
Thats what Ive found
Rotors dont really warp, pad material imprints on them and causes the pedal to pulse and the wheel to shake.
The phenomena is called non-uniform pad imprinting.
Ive seen a hundred rotors on a lathe and have yet to see one thats warped.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
