Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
131 registered members (Anthony, Alfred_B, 1978elcamino, ABerns, 11 invisible), 3,620 guests, and 22 spiders.
Topics300,354
Posts5,174,023
Members70,491
Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims #5286714 12/06/19 09:04 AM
G
GON Online Content OP
OP Online Content
G
I have a 2002 Ford F350 with factory 265 75 r16 rims and tires . I came across a set of Lt245/75R/16 Blizzacks off a Chevy 3/4 ton.
Seeing if I can mount the Lt245/75R/16 from the Chevy on my factory ford rims?
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5286717 12/06/19 09:12 AM
B
bullwinkle Offline
B
As long as the rims aren’t too wide for them. I’ve gone the other way with LT265s & 285s in place of 245s. Look here-
bridgestonetire.com .
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5286758 12/06/19 10:01 AM
G
GoldDot40 Offline
G
I'd be concerned about the load rating on those 245 tires on a 3/4 ton.
Equal Opportunity Offender
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5286792 12/06/19 10:48 AM
SteveSRT8 Offline
Are they load range E or just regular LT tires?
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5286794 12/06/19 10:50 AM
Dave9 Online Content
Online Content
Yes but is it worth the bother? I mean are you going to run those year round or swap tires back and forth? I would sooner get a new set of rims from a junkyard then you're only swapping wheels every winter.
Load range as a lot to do with how much you load the vehicle. Only you can calculate that.
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5286835 12/06/19 11:42 AM
J
JMJNet Online Content
Online Content
J
IIRC, from reading forums, the Chevy and Ford truck rims/wheels are not interchangeable in terms of bolt pattern.
I can be wrong, though, since I have never own a Ford.
  • 2017 Toyota Sienna
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5286920 12/06/19 01:26 PM
G
OP Online Content
G
Thanks for the replies. Yes, the tires are "E" load rated.
The 245s will be used just for the winter, I have an extra set of rims for the rest of the year.
The factory OEM Ford rims will stay with the vehicle, but instead of running 265 75 r16 tires, I want to run Lt245/75R/16.
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5286954 12/06/19 02:08 PM
R
Rand Offline
R
without getting into any of the specifics, It should work.. check the tires recommended and acceptable wheel size to your wheels on tirerack or bridgestone's site.
6.5-8.0 is usuallythe acceptable wheel width for those and similar tires.
how old are these blizzaks? check their date code, are they LT or p-metric what model blizzak(there are about 30 models)
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5286985 12/06/19 02:48 PM
M
Miller88 Offline
M
I've had 215/85R16 and 245/75R16 on the factory 16x7 steelies on my 01 F350 before without issue
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: JMJNet] #5287088 12/06/19 04:50 PM
B
bullwinkle Offline
B
Yes, and no-the center pilot hole is smaller on a Chevy, so Chevy wheels won't go on a Ford-BUT Ford wheels work just fine on an 8-lug GM (the Sierra C3500 in my sig actually has 4 Ford wheels on it right now, & it's studded snow tires are also on Ford wheels). Dodge is even the same lug pattern, but the offset is different (on truck wheels), along with pilot hole size. All are 8 lug by 6.5".
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5287090 12/06/19 04:52 PM
B
bullwinkle Offline
B
To the OP-I was looking at this, and LT245/75R16 tires can generally be mounted on a wheel as thin as 6" wide, so I think you're GTG.
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5287529 12/07/19 08:29 AM
CapriRacer Offline
If I have this right, your F-350 specifies 75/80 psi in your LT265/75R16 tires (front/rear). That means the LT245/75R16's have less load carrying capacity - by about 350# per tire.
This does not sound like a good idea.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: CapriRacer] #5287630 12/07/19 10:57 AM
G
OP Online Content
G
Thanks for pointing this out. I was just looking for one season of snow tires, no hauling or towing.
Went to Discount Tire this morning to mount the tires. I was first in line. They quickly pulled the truck into a bay, unloaded the 245s. Came back a few minutes later with the same concern you identified- and refused to mount the tires.......
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: GON] #5290430 12/10/19 01:04 PM
dareo Offline
Some trims are spec'd to have LT 265 75 16 and some are spec'd 245 75 16. For example my E350 superduty 7.3 diesel van only asks for the 245.
So technically your 245/75/16 would be less capacity, but still over 3000lb a tire. Your curb weight plus payload has got to be no where near that.
Another option, 235 85 16 size, will give great winter performance but similar weight carrying as the 245 75.
2018 Regal TourX, 2016 Golf Wagon 5MT, 2016 GMC 1500 SLT 6.2
Re: Can I put Lt245/75R/16 on a 3/4 ton needing 265 75 16 on same rims [Re: dareo] #5295385 12/15/19 07:21 PM
G
OP Online Content
G
Good info, thanks for posting some additional options Dareo
