AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
Limitations on bluetooth OBDII scanners?
by jayjr1105 - 01/20/20 03:27 PM
Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
91 registered members (750IX, 67ZL1, 25ring, 53' Stude, 928, 7 invisible), 2,584 guests, and 21 spiders.
Topics300,360
Posts5,174,165
Members70,491
Page 1 of 4 1 2 3 4
Honda OEM starter vs aftermarket??? #5285447 12/04/19 10:40 PM
G
Garyd Offline OP
G
My 2008 Honda Element needs a new starter. I am being told I should only use a OEM Honda starter because aftermarket starters tend to fail. OEM Honda starters run around $550 for reman and $1200 for new from my local Honda dealerships parts dept. Aftermarket reman or new are significantly less with some being as low as $78! Is this true about Honda OEM vs Aftermarket?
Replacing the starter is a major job that requires the intake manifold and throttle body to be removed to reach it and I don't feel like I have enough expertise to do the job myself so I'm going to have a shop do it. One shop uses only Honda OEM and is (of course) charging a high price ($850 +) and the other shops I'm looking at use aftermarket and are charging around $500+. Trying to figure out which would be the best direction for me to go.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285454 12/04/19 10:47 PM
Chris142 Offline
I would find out who makes the OEM starter and buy one from them and bypass the stealer.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285460 12/04/19 10:57 PM
Chris142 Offline
It does not look too bad on this video.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285462 12/04/19 11:01 PM
U
user52165 Offline
U
First You Tube I found with 30 second search showed how to do it from below. A good mechanic could do it in one hour. Same as 2007 Civic which this 75 y.o. did recently on ramps in my driveway.
I didn't use OEM, but highly rated Amazon unit.
This:https://smile.amazon.com/gp/product/B00KY0LN98/ref=ppx_yo_dt_b_search_asin_title?
PG Gear has served me well, but not sure if they make for your car.
Well there it is.
Chris posted it while I was typing.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285467 12/04/19 11:08 PM
SLO_Town Offline
OP:
I'd use a Honda dealer remanufactured OEM unit. I had mine replaced by the Honda dealer in 2014. Total cost was $797 even.
Question - is this Element important to you? If so, buy a new one or get a remanufactured OEM one. I've had over 30 cars in my life, most of them really nice units. But by far, our Element is one of the absolute best vehicles I've ever owned. I bought mine new and it has 197k miles on it now. I put new OEM brakes on it at 125k miles and replaced the right strut bearing at 165k miles. Other than routine maintenance that car has cost me nothing other than gas and tires. If you like and depend on your Element as much as I do, don't scrimp on the starter. Elements are worth it.
Scott
03 BMW E46 330Ci ZSP (BMW TPT 5W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285477 12/04/19 11:22 PM
slacktide_bitog Offline
You could try this one
The 2009 should be the same, right?
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285487 12/04/19 11:38 PM
SLO_Town Offline
I'm not throwing stones at you slacktide, but I would worry about that being a counterfeit unit.
Scott
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285488 12/04/19 11:40 PM
ctechbob Offline
I just purchased a Premier Gear from Amazon for my TL about 2 weeks ago. The factory one had become slow and started randomly taking 2 attempts to get it to 'catch'. The PG is working fine and there was no core charge so the OEM one is sitting on my toolbox waiting for me to pull it apart, clean it up, lube it, and put the $14 set of new brushes in it so that I can have it as a spare. What that means is that the PG will probably last the life of the car since I have a backup and its only about an hour job start to finish.
I've never had a problem with aftermarket, but I know people who have. All boils down to what you're willing to put up with I suppose. If its only a minor hassle to swap it out, then I feel aftermarket is worth the cost savings. If you are paying someone to do the work for you, it might be false economy if it fails in a month and you're having to pay the labor again.
FWIW, it is a Mitsuba starter, good source for parts lookup:
https://www.aspwholesale.com/starters/mitsuba/pmgr/starter-p10291.html
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Honda OEM starter vs aftermarket??? [Re: Chris142] #5285535 12/05/19 03:20 AM
G
Garyd Offline OP
G
Yes, I've seen this and other videos on youtube taking the starter from the bottom. But since I don't have a rack, I can't do it by laying under the car because of a recently injured back. This does look like the best way to replace this starter instead of doing it from the top but all shops and dealers I've talked to, do it from the top.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285538 12/05/19 03:41 AM
G
GMBoy Offline
G
I have had good luck with TYC new starters. Rockauto has one for your Element for $105. Also, you can get REMY or AC DELCO new for $170. That's how I would go - and save hundreds of dollars.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285539 12/05/19 03:42 AM
G
GMBoy Offline
G
I would NOT go with a Duralast or Orielly Rebuilds.
Re: Honda OEM starter vs aftermarket??? [Re: SLO_Town] #5285541 12/05/19 03:51 AM
G
Garyd Offline OP
G
I agree, My Element has been one of the best cars I've ever owned. I posted this to find out if the OEM really is the best because I want to put the best starter in my Element so it will last at least another 12 years before I have to replace it again.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285548 12/05/19 04:27 AM
Char Baby Offline
You may have just answered your own question.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285577 12/05/19 05:54 AM
2
2010Civic Offline
2
I put a $25 used OEM starter in my 2005 Accord probably 5+ years ago. Still works great.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Honda OEM starter vs aftermarket??? [Re: Char Baby] #5285579 12/05/19 06:00 AM
G
Gebo Offline
G
I concur. You aren't gonna be happy with a non-OEM starter. You know me and Char Baby are telling the truth.
thumbsup
I would go with the OEM shop as they are making a statement as to the quality of their work. IMHO
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
PP HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Page 1 of 4 1 2 3 4
