Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
130 registered members (77GrandPrix, AC1DD, 4WD, 330indy, 03cvpi, Aero540T, 10 invisible), 2,455 guests, and 20 spiders.
Topics300,650
Posts5,180,236
Members70,541
Page 2 of 2 1 2
Re: Nail stuck in brand new tires [Re: MetalSlug] #5283695 12/03/19 07:55 AM
P
paoester Offline
P
I used this a while back after a screw got in. Pulled it out at a tire pump, did this repair on the spot, and I think it might be permanent. They say it isn't permanent. It might be! No need to take the tire off. I think I used the Slime brand one, but any like this (walmart, etc.):
[Linked Image from i5.walmartimages.com]
Re: Nail stuck in brand new tires [Re: MetalSlug] #5283699 12/03/19 08:00 AM
G
Gebo Offline
G
Yes. Let the tire shop decide how to repair. It may just need removing. IDK??
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
PP HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Nail stuck in brand new tires [Re: MetalSlug] #5283955 12/03/19 12:24 PM
M
MetalSlug Offline OP
M
Thanks everyone , I will take to Walmart where I got 4 tires install . Holiday , a lot of travel , I just back 1000 miles round trips
I don’t want make another thread
But my oil life monitor say 40% life left . When exactly it need to be change . Wait for 10% ? Thanks again
Re: Nail stuck in brand new tires [Re: MetalSlug] #5283973 12/03/19 12:44 PM
The Critic Offline
Your owners manual will answer that question for you... wink
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Nail stuck in brand new tires [Re: MetalSlug] #5283992 12/03/19 01:02 PM
Q
quint Offline
Q
A nail in the tire after two months? I wish. My wife called me and said "There is a chunk of rebar sticking out of the sidewall of one of the rear tires". This was literally less than 24 hours after just I had all four tires installed. I had opted out of the road hazard warranty. The guy at the tire store was gracious but did give me a big dose of "I tried, but you kept saying no...."
Re: Nail stuck in brand new tires [Re: MetalSlug] #5284041 12/03/19 02:20 PM
J
JTK Offline
J
The worst part of it is, brand new tire or not, get a nail close to the edge of the tread and you have to do a DIY plug if you want to keep the tire. Tire shops won't want to touch it. "Nope.. Too close to the sidewall". Been down that road twice in the past few years.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Nail stuck in brand new tires [Re: MetalSlug] #5284193 12/03/19 05:05 PM
M
M
Just back from Walmart . The tech pull off the screw but he say no damage to the tires . No need repair or he can make extra repair ...... my choice was took the key and drive home grin2
Re: Nail stuck in brand new tires [Re: MetalSlug] #5284760 12/04/19 09:15 AM
P
paoester Offline
P
OK, so it didn't puncture.
Still I wonder how long my T-handle gooey rubber-resin-glue plug will hold. So far 3,000 miles. We'll see.
They say it can't be done. I'm a pioneer.
Re: Nail stuck in brand new tires [Re: MetalSlug] #5284771 12/04/19 09:30 AM
demarpaint Offline
Sometimes you get lucky. It looks like that was the case here.
God Bless Our Troops
Re: Nail stuck in brand new tires [Re: paoester] #5285458 12/04/19 10:52 PM
Srt20 Online Content
Online Content
I've used tire plugs for years and years. Never ever had one fail. I used them in sidewalls as well. My wifes Jeep with 5,000 miles on it got a nail. I plugged it. My race car tires got holes, I plugged them. My UTV got a big hole, had to use 4 plugs. Used that tire until it wore out.
Im not saying tire plugs are the only way to go, but Ive never had a problem with them and Im sure Ive used over 100 plugs in my life on all sorts of different styles of tires.
Re: Nail stuck in brand new tires [Re: Srt20] #5285513 12/05/19 12:39 AM
P
paoester Offline
P
Wow. Good rich experience. Mine seems solid. I don't believe the package label saying its not permanent.
Re: Nail stuck in brand new tires [Re: MetalSlug] #5285552 12/05/19 04:38 AM
L
Lubener Offline
L
Have a plug kit handy and pull the nail. If it leaks, a plug will be fine and last the life of the tire. I never get them patched.
The "thinking" man's friend.
Re: Nail stuck in brand new tires [Re: MetalSlug] #5285640 12/05/19 07:27 AM
CapriRacer Offline
So I'm the guy who breaks the statistics about plugs. I've had 2 out of 4 leak.
I'm also the guy who has talked to others who have had troubles with them leaking.
Are plugs a viable temporary solution to a leaking tire? Yes!
Are the 100% guaranteed not to fail? No!
Do they fail more often than the tires themselves? From what I have seen, Yes!
Do plugs fail more often than patches? Yes, I've never seen a patch fail except when it was on the sidewall.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Page 2 of 2 1 2
