What Are The Gun Laws Like In Canada?
by BlueOvalFitter - 01/17/20 10:27 AM
OEM F150 battery finally giving up after 9 years
by volk06 - 01/17/20 10:05 AM
My 2013 Honda Fit Undercarriage after
by TDOHGL01 - 01/17/20 09:08 AM
Oil that won't clog the catalytic converter?
by Underdawg - 01/17/20 08:46 AM
Rear Struts Recommendations
by willbur - 01/17/20 07:46 AM
Critical Windows 10 Update
by doitmyself - 01/17/20 07:38 AM
Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
114 registered members (1978elcamino, 750IX, 330indy, Alfred_B, 15 invisible), 2,266 guests, and 25 spiders.
Topics300,226
Posts5,171,268
Members70,452
Most Online3,728
Jan 11th, 2020
Page 3 of 3 1 2 3
Re: Ceratec and Mos2 Discussion [Re: DrDanger] #5280010 11/28/19 08:30 PM
T
Trav Offline
T
Originally Posted by DrDanger
Oil is getting swooshed in the pan. Sometimes more violent than others. Oil pressure was not the right word.
Look up windage tray, it is there to prevent the exact thing you mention. Small OPE engines and some old engines from the 30's and 40's that use dippers will have more turbulence in the crankcase.
Once the MoS2 has settled it does not come out with the next oil change, it builds up on the bottom of the pan.
Re: Ceratec and Mos2 Discussion [Re: Trav] #5280047 11/28/19 09:51 PM
DrDanger Offline
Looked up windage trays. Some cars have them, some dont.
Looks like it is model dependent. How would the moly get out with an oil change if it is not carried/suspended by the oil.
Check the UOA on the previous page - moly seems in suspension.
Happy Thanksgiving!
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5280077 11/28/19 11:36 PM
O
OS4A Offline
O
Seems like it comes down to...LM M0S2 is ok for daily driver since it won't fall out of suspension. LM M0S2 is a no go for vehicles that sit for weeks or months on end.
Lubeguard Biotech if concerned at all about falling out of suspension or desire the different formulation.
I've used both in daily drivers with no repercussions. I stress my experience is with daily drivers only.
Good info as always on BITOG!
2019 Subaru Impreza 5-door Rotella T6 MV 5w-30 PBL14615 filter
2018 Honda Clarity PHEV Castrol Bio-Synthetic 0w-20 PBL14610 filter
2017 Toyota Rav4 Hybrid Castrol Bio-Synthetic 0w-20 PBL25608 filter
Re: Ceratec and Mos2 Discussion [Re: DrDanger] #5280117 11/29/19 04:24 AM
demarpaint Offline
Happy Thanksgiving!
The point is not all of it stays in suspension, what falls out stays out and collects and remains in the bottom of the pan. The longer you use the product eg: [add a bottle at each OCI] the more it will collect in the bottom of the pan in vehicles that aren't driven everyday.
God Bless Our Troops
Re: Ceratec and Mos2 Discussion [Re: DrDanger] #5280532 11/29/19 03:37 PM
T
Trav Offline
T
Happy Thanksgiving!
Sometimes the gasket itself is acting as a windage tray. the point is without something to prevent turbulence from the pistons aeration can become an issue with dire consequences.
Gasket..
[Linked Image]
Re: Ceratec and Mos2 Discussion [Re: OS4A] #5280631 11/29/19 06:22 PM
DrDanger Offline
Yes, can agree with that!
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5281317 11/30/19 04:42 PM
B
BMWTurboDzl Offline
B
Would not use any of these products in any engine which has VVT.
These systems typically contain fine mesh screens to filter out small solids.
In addition I've yet to come across a compelling reason to use these products. Maybe 30+ years ago. After all has LM ever provided any studies on the effectiveness of these products in a modern engine?
435i
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5281856 12/01/19 10:40 AM
K
Kamele0N Offline
K
According to BITOG...MoS2 (and MoDTC & Mo.... Even more?) has beneficial effects on (valve) chains...
Thats why I am using Motul gearoil with MoS2 in my transmission case...and a tad of LM in oil of my yaris...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Ceratec and Mos2 Discussion [Re: Kamele0N] #5282685 12/02/19 08:42 AM
W
wag123 Online Content
Online Content
W
MoS2 should NOT be used in a manual transmission. It will cause the syncros to become non-functional. Get it out of there ASAP!
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5282698 12/02/19 08:57 AM
K
Kamele0N Offline
K
Tnx...I know that...
I meant transfer case...sorry "my misteyka"...wanted to say" in my tranny".....but that (could) sound so...odd smile
Page 3 of 3 1 2 3
