Wiring up a 240vac hour meter to air compressor?
by motor_oil_madman - 04/01/20 11:04 AM
BMW 328D?
by meep - 04/01/20 10:19 AM
A moment of silence...😟
by Mad_Hatter - 04/01/20 09:20 AM
Shaving costs during this time
by Bighorn2500 - 04/01/20 08:25 AM
Bosch Premium 3410
by QuangTeo - 04/01/20 03:48 AM
Thicker oils are coming back to USA
by Kamele0N - 04/01/20 03:07 AM
misty air coming out of air hose even with water separator?
by motor_oil_madman - 03/31/20 11:22 PM
Post your favorite racing cars
by IMSA_Racing_Fan - 03/31/20 09:40 PM
Air Filters for Chonda 457cc engine
by 92saturnsl2 - 03/31/20 07:59 PM
Share your Hot Toddy recipe
by LoneRanger - 03/31/20 07:24 PM
Aftermarket CV axle boot replacement
by CDX825 - 03/31/20 06:34 PM
A few discounts at Walmart for buying 2 jugs
by jayjr1105 - 03/31/20 06:20 PM
Bumblebee Ahi tuna poke
by atikovi - 03/31/20 06:05 PM
2007 RDX Differential and Transfer Case?
by maverickfhs - 03/31/20 06:02 PM
Tacky additive in bar and chain oil
by TreyT42 - 03/31/20 05:02 PM
How Come Diesel is $2.69 when gas is $1.47 ?
by LoneRanger - 03/31/20 04:42 PM
Bosch Premium 3422 Cut Open
by getawheel - 03/31/20 03:52 PM
AC Went out in my Forester Again
by Miller88 - 03/31/20 03:48 PM
I'm out on the Front Porch
by MolaKule - 03/31/20 03:11 PM
mtnrider, Rickborn, TreyT42, Abi, Transpections
71069 Registered Users
105 registered members (1978elcamino, 2015_PSD, 55hambone, 007, 2K2AcuraTL, 555, 6 invisible), 2,553 guests, and 20 spiders.
Topics303,420
Posts5,235,061
Members71,069
Page 2 of 2 1 2
Re: Exhaust clamps, regular or guillotine? [Re: Silverado12] #5281799 12/01/19 10:39 AM
A
atikovi Offline OP
A
Originally Posted by Silverado12
A guy at the muffler shop showed me a trick a long time ago. He used high temp silicone RTV on the joints and it lasts the life of the exhaust system for sealing minor leaks. Sometimes you slightly deform a joint when you take apart the system and this will prevent leaks.
You sure it wasn't exhaust sealant made specifically for mufflers and pipes? Can't imagine silicone holding up under the heat and pressure.
[Linked Image from images-na.ssl-images-amazon.com]
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281841 12/01/19 11:18 AM
M
Mainia Offline
M
No, while both will work, modern day high temp silicone works and is more fluid and seals better.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281853 12/01/19 11:36 AM
E
eljefino Offline
E
Silicone works fine after the cat as exhaust cools down by then. They sell orange RTV that claims high temp.
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281980 12/01/19 01:36 PM
Dave9 Offline
If your pipes fit together that badly (that you feel you need a sealant), why not just expand the smaller one till they're a tighter fit?
The cheap plain steel clamps have their place, but if you want to get it apart again later, with less effort and destruction, avoid the goop and just put a band clamp on tight fitting pipes. Make it stainless if you anticipate some portions of the exhaust wearing out faster than others, for example using a stainless muffler with an aluminized pipe after it instead of stainless, so there is a greater possibility you will need to remove that clamp instead of just detaching or cutting out the parts on both sides of it.
The piece at the bottom (screw end) of the band clamp is not much of an issue. Yes it has a fixed curvature, but it is pretty close per the pipe diameter, you are putting this on thin walled tubing so as you tighten it, the tubing conforms that slight bit to that curvature.
Page 2 of 2 1 2
