Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
by tenderloin - 02/27/20 09:59 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
Ford to reduce warranty costs ?
by marine65 - 02/27/20 06:02 PM
Sony MEX-GS820BT, good AM/FM?
by sasilverbullet - 02/27/20 05:59 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
49 registered members (bbhero, Avery4, allgm59, ArrestMeRedZ, AC1DD, BLND1, 4 invisible), 1,137 guests, and 23 spiders.
Topics302,026
Posts5,207,453
Members70,819
Page 3 of 4 1 2 3 4
Re: Ceratec and Mos2 Discussion [Re: DrDanger] #5280010 11/28/19 08:30 PM
T
Trav Offline
T
Originally Posted by DrDanger
Oil is getting swooshed in the pan. Sometimes more violent than others. Oil pressure was not the right word.
Look up windage tray, it is there to prevent the exact thing you mention. Small OPE engines and some old engines from the 30's and 40's that use dippers will have more turbulence in the crankcase.
Once the MoS2 has settled it does not come out with the next oil change, it builds up on the bottom of the pan.
Re: Ceratec and Mos2 Discussion [Re: Trav] #5280047 11/28/19 09:51 PM
DrDanger Offline
Looked up windage trays. Some cars have them, some dont.
Looks like it is model dependent. How would the moly get out with an oil change if it is not carried/suspended by the oil.
Check the UOA on the previous page - moly seems in suspension.
Happy Thanksgiving!
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5280077 11/28/19 11:36 PM
O
OS4A Offline
O
Seems like it comes down to...LM M0S2 is ok for daily driver since it won't fall out of suspension. LM M0S2 is a no go for vehicles that sit for weeks or months on end.
Lubeguard Biotech if concerned at all about falling out of suspension or desire the different formulation.
I've used both in daily drivers with no repercussions. I stress my experience is with daily drivers only.
Good info as always on BITOG!
2019 Subaru Impreza 5-door Rotella T6 MV 5w-30 PBL14615 filter
2018 Honda Clarity PHEV Castrol Bio-Synthetic 0w-20 PBL14610 filter
2017 Toyota Rav4 Hybrid Castrol Bio-Synthetic 0w-20 PBL25608 filter
Re: Ceratec and Mos2 Discussion [Re: DrDanger] #5280117 11/29/19 04:24 AM
demarpaint Offline
Happy Thanksgiving!
The point is not all of it stays in suspension, what falls out stays out and collects and remains in the bottom of the pan. The longer you use the product eg: [add a bottle at each OCI] the more it will collect in the bottom of the pan in vehicles that aren't driven everyday.
God Bless Our Troops
Re: Ceratec and Mos2 Discussion [Re: DrDanger] #5280532 11/29/19 03:37 PM
T
Trav Offline
T
Happy Thanksgiving!
Sometimes the gasket itself is acting as a windage tray. the point is without something to prevent turbulence from the pistons aeration can become an issue with dire consequences.
Gasket..
[Linked Image]
Re: Ceratec and Mos2 Discussion [Re: OS4A] #5280631 11/29/19 06:22 PM
DrDanger Offline
Yes, can agree with that!
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5281317 11/30/19 04:42 PM
B
BMWTurboDzl Offline
B
Would not use any of these products in any engine which has VVT.
These systems typically contain fine mesh screens to filter out small solids.
In addition I've yet to come across a compelling reason to use these products. Maybe 30+ years ago. After all has LM ever provided any studies on the effectiveness of these products in a modern engine?
435i
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5281856 12/01/19 10:40 AM
K
Kamele0N Offline
K
According to BITOG...MoS2 (and MoDTC & Mo.... Even more?) has beneficial effects on (valve) chains...
Thats why I am using Motul gearoil with MoS2 in my transmission case...and a tad of LM in oil of my yaris...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Ceratec and Mos2 Discussion [Re: Kamele0N] #5282685 12/02/19 08:42 AM
W
wag123 Offline
W
MoS2 should NOT be used in a manual transmission. It will cause the syncros to become non-functional. Get it out of there ASAP!
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5282698 12/02/19 08:57 AM
K
Kamele0N Offline
K
Tnx...I know that...
I meant transfer case...sorry "my misteyka"...wanted to say" in my tranny".....but that (could) sound so...odd smile
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5344650 02/08/20 01:12 PM
T
TiGeo Offline
T
Ceratec last change and it's supposed to be good for 30k. Will go MoS2 this time around.
2018 VW Atlas SEL 4Motion 3.6 - Castrol OE 5W40 VW filter
2018 VW GSW S 4Motion 1.8 Unitronic St2 IS20 - LiquiMoly 5W40 VW filter+Ceratec/MoS2
2013 Ford Focus SE HB 2.0 - MC syn-blend 5W20 MC filter
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5356171 02/21/20 03:19 AM
O
Olas Offline
O
Re moly falling out of suspension;
My hunnch is that gravity will pull the particles to the bottom of the sump pan. Incidentally, the oil pick up is located at the bottom of the sump pan! Further, the bottom of the majority of sump pand is not flat but angled toward the pickup (and drain plug, theyre usually close to one another.)
as the pickup sucks up oil from the bottom of the pan, what mechanism do we assume to be at work to keep the moly seperate from the oil? how does the pickup differentiate and choose what it picks up?
lastly, why does oil retain the silver colour of mos2 if it has all fallen to the bottom of the pan? what dye or colourant is in use?
Re: Ceratec and Mos2 Discussion [Re: Olas] #5356204 02/21/20 05:46 AM
demarpaint Offline
If you haven't seen pictures of MoS2 collected at the bottom of an oil pan, PM Trav. His pictures ended several members from using the product, especially in vehicles that aren't driven everyday. He had similar observations with Ceratec in a compressor.
Re: Ceratec and Mos2 Discussion [Re: DV0993] #5356213 02/21/20 06:16 AM
dogememe Online Content
Online Content
No thanks, the oil is fine the way it is. I've tried various additives and nothing seems to actually do anything beyond wasting money.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Ceratec and Mos2 Discussion [Re: dogememe] #5356321 02/21/20 08:55 AM
T
Trav Offline
T
You may as well open the window and throw the money out into the wind, same effect. Lighter wallet nothing more.
Page 3 of 4 1 2 3 4
