Altimax RT43 snow review
by Skippy722 - 12/16/19 04:59 AM
New TV Audio Question
by Toros - 12/16/19 01:25 AM
is on car rotor cutting the best method?
by WhyMe - 12/16/19 12:37 AM
Found a Good deal!!!
by GuinnessGuy - 12/15/19 11:28 PM
Serpentine Belt Change
by Propflux01 - 12/15/19 08:59 PM
QS HM 10W-40
by kstanf150 - 12/15/19 08:29 PM
4.5" Angle Grinder
by TheLawnRanger - 12/15/19 07:51 PM
Cooper CS5 Ultra Touring
by Warstud - 12/15/19 07:39 PM
Highway power loss
by HyundaiAbuser - 12/15/19 07:21 PM
General truck tires
by spasm3 - 12/15/19 07:18 PM
Alternative uses for CVT fluid?
by stroo - 12/15/19 05:57 PM
CANbus mileage editor
by cwilliamsws6 - 12/15/19 05:56 PM
Fed ex
by Chris142 - 12/15/19 05:53 PM
New oil treatment from Colgin
by qball16 - 12/15/19 05:36 PM
Discount Tire Direct $80 Flash Sale
by BePrepared - 12/15/19 05:16 PM
Bleed and refill?
by cwilliamsws6 - 12/15/19 04:19 PM
Pies: which ones do you love?
by 53' Stude - 12/15/19 02:32 PM
bjonga, theman5142, 750IX, Tzam, tjl5709
70138 Registered Users
62 registered members (2009Edge, alarmguy, Astro_Guy, askani79705, 750IX, 2015_PSD, 4 invisible), 1,000 guests, and 20 spiders.
Topics298,857
Posts5,142,701
Members70,138
Most Online3,589
Nov 2nd, 2019
ATF for a MP3010 Transfer case?? #5273897 11/21/19 06:34 PM
N
nitecop Offline OP
N
I know it is factory fill, but.... Here is what happened,
I have a good friend that has a 13 Grand Cherokee with the Quadratrac I (Full time 4x4 single speed case with a open diff inside)
And suddenly it gets the Very loud popping of the chain jumping gears.
we put in his garage and put up on stands, as i am taking off all the "Stuff" required to be removed to get to the case i decide to drain the case.
I GET TWO DROPS of fluid of the drain plug!! and 2 drops only!! (112K on the ODO)
He bought he vehicle new and said he never saw any leaks. The case is apart now and looks like the fluid was a bit cooked. The bearing are nice and smooth. It seems like is just needs the new chain and sprockets.
He tell he has read they have a reputation for boiling out the ATF. He now tells me he has heard that the factory says we must Pack the bearing with grease that will with stand ATF?!!
I'm not so sure there is a grease that can withstand boiling ATF
Maybe it would better lubed by some 5W-40 SYN Rotella?? OR 10W30 Mobil One. Aren't these better for lube than ATF for higher temps anyway?
Re: ATF for a MP3010 Transfer case?? [Re: nitecop] #5273944 11/21/19 07:23 PM
MolaKule Offline
Global Moderator
Global Moderator
Sounds like the problem was not one of fluid viscosity but one of no fluid.
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: ATF for a MP3010 Transfer case?? [Re: nitecop] #5274039 11/21/19 09:18 PM
Snagglefoot Online Content
Online Content
From the 2013 Jeep Cherokee owners manual the single speed (Quadra Track I) specs Shell Automatic Transmission Fluid 3353. If it was a 2 speed (Quadra Track II) it would spec ATF+4.
Having said that you might check some four wheeler forums.
If you want the job done right......do it yourself.
Re: ATF for a MP3010 Transfer case?? [Re: nitecop] #5274072 11/21/19 09:53 PM
Online Content
I wouldn’t think the ATF was boiling. You need 600 F for that. A slow drip for 6 years would empty it. I have a MP3024. No lost fluid whatsoever in 11 years of operation. Maybe some oil change tech let it out by mistake.
Re: ATF for a MP3010 Transfer case?? [Re: Snagglefoot] #5275489 11/23/19 01:39 PM
N
nitecop Offline OP
N
I really didn't think it was boiling the oil as well. I was skeptical of his information. I asked his if He ever used a quick lube type of oil change. He said No always just him. But its his vehicle. We were proceeding cautiously as he could only get one of the sprockets from the dealer. Once apart I measured the sprockets and they was only .001 difference between the new and old so shoved some good grease in the bearings like he wanted and put the halves back together. I'm going to start reinstall monday.
