2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
89 registered members (Aero540T, 4WD, aquariuscsm, alcyon, 2015_PSD, andreigbs, 9 invisible), 1,998 guests, and 49 spiders.
Topics298,361
Posts5,133,797
Members70,047
Most Online3,589
Nov 2nd, 2019
Fram PH2 ExtraGuard Cut Open #5270210 11/17/19 06:38 PM
A
A310 Offline OP
A
This filter is off my 2000 Ford Excursion with 202,850 miles. The oil has a total of 40,000 miles with 15000 miles on this Fram filter and running a MotorGuard bypass filter. Some debris on the bottom and is non metallic, most likely carbon. Pleats are in great shape and have a very small amount of carbon and a few specs of metal. Looks like I'll go 30,000 miles on the next filter.:)
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Fram PH2 ExtraGuard Cut Open [Re: A310] #5270219 11/17/19 06:48 PM
A
A310 Offline OP
A
The engine is the V10 Triton, 6.8 ltrs.
Re: Fram PH2 ExtraGuard Cut Open [Re: A310] #5270225 11/17/19 06:56 PM
Corollaman Offline
Looks good, nothing wrong with Fram extra guard filters.
Re: Fram PH2 ExtraGuard Cut Open [Re: A310] #5270256 11/17/19 07:35 PM
53' Stude Offline
Looks like it caught a bunch of stuff. What filter and oil went back in and on. Thank You
Last edited by dnewton3; 11/18/19 06:31 AM. Reason: removed embedded quote duplicate
Re: Fram PH2 ExtraGuard Cut Open [Re: 53' Stude] #5270265 11/17/19 07:46 PM
A
A310 Offline OP
A
The replacement filter is a Wix 51372 and I added a quart of Quaker State 5W20 dino. There was no oil change, just the filter. Oil has a total of 40,000 miles on it with bypass filter changes every 4000 miles and a quart of top up oil added.
Last edited by dnewton3; 11/18/19 06:32 AM. Reason: removed embedded quote duplicate
Re: Fram PH2 ExtraGuard Cut Open [Re: A310] #5270268 11/17/19 07:47 PM
53' Stude Offline
Sounds good sir:)
Thank You
Re: Fram PH2 ExtraGuard Cut Open [Re: A310] #5270282 11/17/19 08:08 PM
9
92saturnsl2 Offline
9
I'd be a dead man if my wife caught me with dirty oil and filters up on the kitchen counter! WWF J/k, if it's a workbench, it's a nice one!
Filter looks good for the mileage. Nothing wrong with Fram EG filters though I tend to shy away from them for extended drains. Is QS 5w20 the original fill? Have you ever had a UOA performed on any of these extended drains? It would be nice to see a UOA on the oil after all those miles.
96 Grand Prix SE (project car)
04 Odyssey EX 200k Philips Shield Choice 10w-30
96 Maxima GLE 275k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 145k Mobil1 EP 0w-20
Re: Fram PH2 ExtraGuard Cut Open [Re: 92saturnsl2] #5270308 11/17/19 08:48 PM
A
A310 Offline OP
A
Lol, my wife is away for a few days.:) The Fram held up better than the previous Wix I changed with 10,000 miles on that filter. The original fill was from the previous owner who claimed it was Mobil 1 5W20. Because it was synthetic he ran 20,000 miles oil change intervals and the fill I got had 15,000 miles on it. At that time it had no bypass, so I changed the filter and added the bypass but did not change the oil. I took an oil sample and sent it to the lab and confirmed one that it wasn't mobil 1 and two that the engine was in bad shape. He was using a quick lube place and they were using cheap dyno , so the engine was badly sludged. 25000 miles later the engine is finally clean and I can now get up to 5000 miles on my bypass before I change it. When I first started the bypass would plug in 500 miles. I take regular oil samples to check the health of the oil and am very happy with the results. Most of the debris in the filter is carbon still washing off the engine, I expect that to diminish as time passes. Now that the engine is clean I can safely due annual oil samples and scheduled bypass filter changes every 4000-5000 miles. I took an oil sample again on this filter change and will post when I get the results. Here was the last sample I took.:) I initially used Mobil 1, but have since gone to conventional oils, Pennzoil and now Quaker State
[Linked Image]
Re: Fram PH2 ExtraGuard Cut Open [Re: 92saturnsl2] #5270309 11/17/19 08:49 PM
J
JGmazda Offline
J
That IS a very nice workbench! Yeah, agreed...
2008 KIA Sportage
Re: Fram PH2 ExtraGuard Cut Open [Re: A310] #5270659 11/18/19 09:46 AM
old1 Online Content
Online Content
Has anybody else noticed that for some time now, that even filters run for extended periods, and ANY make, seem to be ok. I can't remember when I last saw any brand with a defect. So, does that mean that filters are better now than they were a while back, and one brand is pretty much as good as another? I use mostly Fram Ultras, but I am sure it is overkill, as I change oil twice a year due to very short trips, and change the filter every other time, with about 8000 miles on it. Of course on my mustang and ranchero, I go 2 years minimum on the filters, as they only get 1 to 2 thousand per year. And it is longer drives, and warm weather.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: Fram PH2 ExtraGuard Cut Open [Re: old1] #5270671 11/18/19 09:57 AM
L
Linctex Offline
L
Modern EFI engines are a LOT easier on oil and filters than their old carbureted ancestors were.
I need to cut open my 50,000 mile Tough Guard, but I've just been so darn busy lately (and I can't take it in to work, LOL! ) - but I'm sure it is fine inside
Re: Fram PH2 ExtraGuard Cut Open [Re: A310] #5270987 11/18/19 04:18 PM
Z
ZeeOSix Offline
Z
Your UOA particle count isn't too good, especially since you have a bypass filter setup. One reason may be because you're over extending the full flow filter. Your PC is in the range where a filter that's rated at 50% @ 20u would typically show up. Could be the bad PC is also because this engine sounds like it's still pretty dirty inside. Think I'd be changing filters more often than you're doing to see if that helps the PC clean up more.
Re: Fram PH2 ExtraGuard Cut Open [Re: Linctex] #5271085 11/18/19 05:36 PM
CR94 Offline
Modern EFI engines are a LOT easier on oil and filters than their old carbureted ancestors were. ...
I normally ran basic filters about 18k miles (3 oil changes) on my carbureted '81 Mazda. Those filters generally "seemed to be OK" inside, too.
2011 Toyota Prius now at 107K
Re: Fram PH2 ExtraGuard Cut Open [Re: A310] #5271474 11/19/19 04:44 AM
L
Lubener Offline
L
Why would anyone want to run a filter for 30k miles?
The "thinking" man's friend.
Re: Fram PH2 ExtraGuard Cut Open [Re: ZeeOSix] #5271476 11/19/19 04:55 AM
4WD Online Confused
Online Confused
Changing the partial flow often and the full flow (cheap one too) at 30 (3x OEM rating).
