2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
madjid, michWB, Brianhefty, JimBremer, Katdaddy
70471 Registered Users
98 registered members (aircooled, 2015_PSD, 4WD, ABerns, 94astro, alarmguy, 7 invisible), 2,553 guests, and 25 spiders.
Topics300,313
Posts5,173,046
Members70,471
Most Online3,728
Jan 11th, 2020
Garage door lack of signal/reception issue #5264443 11/11/19 06:05 PM
dja4260 Offline OP
I just installed a RYOBI 2hp garage door opener in my detached all metal workshop.
I love the opener and have an awesome 30ft extension cord attachment. With that said, my outside key pad doesn't work and I need to be 5 feet away from the door for an opener (clicker) to work....
Do I have any options to increase the range of this unit? I didn't think signal would be this poor......
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264445 11/11/19 06:09 PM
Skippy722 Offline
Are there any LED’s near the key pad or garage door opener? I had a wonky led that was giving off interference if it was on.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264448 11/11/19 06:11 PM
K
KevGuy Offline
K
After spending a few summers while in school helping repair or install garage door openers, the only opener I would go with is Chamberlain.
Do not fear the orange can.
Re: Garage door lack of signal/reception issue [Re: KevGuy] #5264451 11/11/19 06:14 PM
R
redbone3 Offline
R
I had a similar problem. I poked a hole in the ceiling of the garage and pushed a pice of really stiff steel wire through the hole. I attached the wire with a screw to the ceiling and attached the antenna wire to it. Works great now. (Problem is trying to get a signal through a metal garage door, this puts the antenna above the metal).
2014 Passat Wolfsburg, 1995 Miata.
Re: Garage door lack of signal/reception issue [Re: redbone3] #5264461 11/11/19 06:30 PM
spasm3 Offline
So you basically made the whole building the antenna!
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Garage door lack of signal/reception issue [Re: Skippy722] #5264477 11/11/19 07:01 PM
dja4260 Offline OP
I have 6, 4 ft LED shop lights directly overhead.....
1997 HD Sportster
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264536 11/11/19 08:00 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Are they on when you're having signal problems?
Re: Garage door lack of signal/reception issue [Re: Kestas] #5264563 11/11/19 08:41 PM
dja4260 Offline OP
No, signal is basically nonexistent with the lights off as well.
1997 HD Sportster
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264613 11/11/19 09:51 PM
Donald Offline
How about when the door is open and you wan to close it? With remote outside but door open? Is that any better?
2015 Ford F-250 w/Powerstroke
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264689 11/12/19 12:55 AM
sxg6 Offline
Reading through some reviews online it looks like Ryobi might be able to send you a larger antenna if you contact them, worth a try.
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264698 11/12/19 01:36 AM
B
billt460 Offline
B
How about any CFL's? I put a CFL in my opener light socket, and the remote quit working. The manual pad worked fine.
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264739 11/12/19 05:56 AM
F
Fawteen Offline
F
Sounds like the opener is in vacation mode (disables the outdoor keypad and the remotes).
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264803 11/12/19 07:49 AM
M
MasterSolenoid Offline
M
I would read over the Owners Manual again looking for solutions.
Try some of the suggestions others have listed here.
Then, call Ryobi's Customer Service.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264809 11/12/19 07:58 AM
6
64bawagon Offline
6
As crazy as it sounds I had an HD TV antenna with a booster in my barn that would mess with the opener. I moved it to the back of the barn.
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Garage door lack of signal/reception issue [Re: 64bawagon] #5264847 11/12/19 08:58 AM
M
M
I had a 'dimmer' Light Switch in Dining Room that would interfere with (over-air signal) TV in Living Room.
2 Wheel Drive
3.0 Liter Engine
