Yeah this is the same CR-V I have toyed with selling but I have to keep it until I graduate at the very least because if I did buy something else now I would have almost zero savings left for insurance and gas (am 18 year old minimum wage HS senior)
Since owning the car I have replaced the VTEC solenoid after it got clogged with sludge and sent the car into limp mode, replaced the oil pressure sensor after that because it quit giving a reading and sent the car into limp mode again, then the power steering pressure line after it began to leak, then the return line because THAT began to leak the next week, then the power steering rack because IT began to leak and I had to refill the reservoir every morning....then the starter went out, then the alternator not even a month later, then the MAF sensor. Not to mention the car is on it's 3rd A/C compressor now. Just recently got done with round #4 of the Takata recall.
Still need to replace some worn out rear suspension components because it's chewing the insides of my tires, replace a rattling exhaust heat shield, get the valves adjusted, flush and refill the Dual Pump II fluid that's overdue, and chase down some fuel system issues because at least once a week I get a CEL for running too lean on bank 1, also still need to do ignition coils I never had the time to change those when I did my plugs last summer. Also need to replace a lock actuator, my right rear door is permanently locked shut you can only open it in the split second after you press the unlock button.
