Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69937 Registered Users
76 registered members (4WD, Aero540T, 007, 53' Stude, 2K2AcuraTL, 01rangerxl, 10 invisible), 1,604 guests, and 22 spiders.
Topics297,761
Posts5,122,050
Members69,937
Most Online3,589
Nov 2nd, 2019
Rate Thread
Delphi ecu and segment swap #5246538 10/21/19 09:06 PM
P
P10crew Offline OP
P
On my 53 project I’m going to get a salvage yard ecu to control a 6.0 with a magnason TVs 2300 and a 4l80e. My question is can I segment swap both trans and motor or should I go after the ecu that was in a 6.0 with 80E?
Re: Delphi ecu and segment swap [Re: P10crew] #5246575 10/21/19 09:55 PM
clinebarger Offline
You can segment swap the Trans Segment on most P01 & P59 Delphi PCM's using the Segment Swapper Utility in HP Tuners. Just make sure the Operating Systems (OS) is the same between the file you download & the PCM you have. You will still need to disable some 4L60E DTC's in the Engine Diag section/menu.
I wouldn't bother with any of the other segments, Your going to need custom tuning anyway & swapping more than one segment just increases chances of "bricking" the PCM.
I'm running a 2005 P59 5.3L/4L60E PCM to run my 6.2L/4L80E using the HP-Tuners Segment Swapper Utility for the 4L80E.
Stock 5.3L & 6.0L calibrations are not that far off from each other, Especially the LM7 vs LQ4!
2001 Chevy Camaro L92/4L80E
Re: Delphi ecu and segment swap [Re: P10crew] #5246582 10/21/19 10:00 PM
P
P10crew Offline OP
P
Very good thanks man👊
