'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
HyunKia Wix 51334XP $6.73 @ Amazon
by SlavaB - 11/18/19 12:18 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
130 registered members (4WD, ABerns, 2015_PSD, 645ja, 01rangerxl, 69GTX, 18 invisible), 2,049 guests, and 21 spiders.
Topics297,607
Posts5,119,049
Members69,908
Most Online3,589
Nov 2nd, 2019
2020 Elantra TPMS INFO and winter tire choices. #5242742 10/17/19 08:08 PM
R
Rand Offline OP
R
I want to run a separate winter tires/wheels set.
Does anyone know how this tpms works... seems overly restrictive and complicated..
The 2020 elantra does have the psi readout from each wheel so its different than the older tpms dummy light that just lit up for an issue.
Seems like I need a tool to even rotate the tires so the psi readout works?
I have a few options as I see it.
Option 1:
Buy sensors and the $250 tpms tool
or
buy sensors and haul the wheels 70miles round trip to have DT put them on and fix the sensors(yearly)
note: i hate hauling tires 1.5 hours and loading/unloading them I can do it in the driveway with 2 floor jacks in about 15min.
also introduces many chances for the "newbie tech" to mess something up etc.
Tirerack wont sell you a wheel/tire combo without TPMS.. well they will but they wont balance the tires.....
Option 2:
Dont buy sensors.--does this affect the Traction control/ESC like on hondas?
If not buying sensors I am pretty sure I can pickup the tires/wheels from DT with my jeep and they will let me slide on the sensors.
Might be for offroad use blah blah resolves them from the federal TPMS mandate.
However would I still need the tpms tool anyway to rotate the factory wheels/all seasons??
Option 3:
Buy good all weather tire such as the nokian WR-G4.
The elantra will get 12000-15000 miles a year, most of the miles are highway commute but we do live on a moderate hill.
Realistically the car has about 5" of ground clearance so it doesnt need to be able to cross a mountain pass with a foot of ice and snow on it..
however I would like it to be reasonably safe on snow and black ice. I already know the stock low rolling resistance tires are not going to cut it.
Comments and ideas? I am flip flopping on the options.. but I could use more info on the TPMS system that might tilt me one way or the other.
Also waiting a few weeks for possible black friday deals seems prudent although sometimes winter tire availability is BAD later in the fall.
Target date for winter tires on car is usually early december... or first major snow storm.
If I decide on winter tires it will most likely be a -1 195/65r15 fitment. stock is 205/55r16
Re: 2020 Elantra TPMS INFO and winter tire choices. [Re: Rand] #5242758 10/17/19 08:33 PM
M
MParr Offline
M
You could always buy 4 extra sensors and put them in a sealed up pvc pipe with a valve stem installed. Air that thing up and put it in your trunk.
2019 VW Tiguan SE Now: Mobil 1 ESP 5W30 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: 2020 Elantra TPMS INFO and winter tire choices. [Re: MParr] #5242787 10/17/19 08:59 PM
R
Rand Offline OP
R
Doesnt work.
My Jeep autolearns any sensors..
the elantra system has to be registered and it holds 4 sensors.
Also they dont properly wake up unless you are driving sometimes (it will say drive to display psi on screen)
Re: 2020 Elantra TPMS INFO and winter tire choices. [Re: Rand] #5242799 10/17/19 09:18 PM
slacktide_bitog Offline
You can get aftermarket sensors like the ITM Uni-Sensor. Less than $100 for the set of 4 on eBay, and they come pre-programmed, so no need to buy the $250 scan tool smile
Re: 2020 Elantra TPMS INFO and winter tire choices. [Re: slacktide_bitog] #5242830 10/17/19 10:06 PM
R
Rand Offline OP
R
How does that work? some type of cloning sensor?
Also how do you realign the sensors with the locations when you rotate tires..
There is a black hole where information about this elantra tpms system should be.
Previously all my vehicles were either jeep with autolearn
or dumb systems with tpms idiot light that didnt need to know which sensor was in which wheel position.
afaik the elantra system doesnt autolearn sensors(ID) or update sensor locations automatically when rotating etc.
edit: I'm not seeing any ITM uni-sensor for anything after 2017 elantra.
Re: 2020 Elantra TPMS INFO and winter tire choices. [Re: Rand] #5242899 10/18/19 03:48 AM
L
LotI Offline
L
Looks like the Autel TS408 has support, it’s $150 at Amazon.
[Linked Image]
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: 2020 Elantra TPMS INFO and winter tire choices. [Re: Rand] #5243137 10/18/19 08:38 AM
K
knerml Offline
K
Suggest that you try your OEM tires out in the snow before switching. The OEM Kumhos on my SFS work great in the snow.
Have been rotating tires on two Hyundais (2017 Elantra & 2018 SFS) with this TPMS system and have had no problems.
If you do buy winter tires, suggest that you wait to see if you actually do have problems adapting the new sensors before looking to change settings.
If you go the all-season route, highly recommend Michelin Premier A/S. Have been running these on our Elantra and work great in the snow.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport AWD 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: 2020 Elantra TPMS INFO and winter tire choices. [Re: Rand] #5259496 11/05/19 09:14 PM
R
Rand Offline OP
R
Well The decision is made.
I was very close to getting michelin xice xi3 but wanting to try something else(previous car had michelin xice xi2) and the large price difference pushed me to the continentals.
I ended up with continental viking contact 7 on alloy wheels from DTD.
no TPMS.
Currently they have a 70 conti mir and
$50 winter tire MIR(requires DT Credit card)
They took #1 in ice braking in a couple tests.
I could have saved $60 and went with last year's wintercontact si model.. but I'm a tire nerd so I had to get the latest model.
I'll post some feedback on them later in the winter and after winter.
This is around my 18th set of winter tires so I'll try to provide some good feedback for anyone else interested.
Will update with pics.. expecting them thurs or fri.
