Havoline ProDS Syn 10W-30 $19.73 6-pack
by Jackson_Slugger - 10/23/19 03:02 PM
Wix Oil Filter Rating Question
by 02vito - 10/23/19 02:30 PM
Help me decide between Fram and Mobil 1
by ZiTS - 10/23/19 02:13 PM
2003 BMW E46 M3 Rotella 15w40
by Manners226 - 10/23/19 02:10 PM
Firearm solvent/oils
by HyundaiAbuser - 10/23/19 01:56 PM
Coloured wax
by Propflux01 - 10/23/19 01:36 PM
Elk Jerky
by 28oz - 10/23/19 01:15 PM
If idle is to be avoided?
by Rglossip - 10/23/19 01:01 PM
Beck Arnley Brake Pads FMSI Materials?
by jrvn - 10/23/19 12:39 PM
Aging - What the ....
by coopns - 10/23/19 12:13 PM
Chevron Supreme 5W20 Bay Area Trade/Sell
by e55amgbenz007 - 10/23/19 10:07 AM
Auto Extra 51348 Vs Napa Gold 1348
by BeerCan - 10/23/19 10:05 AM
Latest Scam Method?
by 2015_PSD - 10/23/19 09:47 AM
Medical bills from 3 year back
by stockrex - 10/23/19 09:31 AM
2019 Nissan Pathfinder CVT drain/fill.
by JTK - 10/23/19 09:19 AM
Do I need Intel RST?
by Quattro Pete - 10/23/19 08:50 AM
Anabond 230 for bonding brake linings
by sdowney717 - 10/23/19 07:29 AM
2010 Mazda 3 FL400s options
by Sixxer - 10/23/19 06:50 AM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
95 registered members (4WD, AdditiveOCD, AC1DD, 2010Civic, 72te27, 02vito, 5 invisible), 2,171 guests, and 34 spiders.
Topics296,391
Posts5,096,795
Members69,652
Most Online3,532
Jul 30th, 2019
Garage high humidity floor wet vehicle inside. #5218946 09/21/19 03:34 PM
L
littleant Offline OP
L
Days when humidity is high (summer or winter) my garage floor will be wet and my 2010 Mountaineer will have beads of water in the body but not always depends how high the humidity is.
My concern are is moisture getting inside the running gear -frame-door and fender panels.
Always garaged never driven in the winter. Just did front and rear differential fluid change and all looked good not milky. I see no water droplets in the oil dip stick. Your opinion would be appreciated.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5218950 09/21/19 03:39 PM
CT8 Online Content
Online Content
Ventilation is a good place to start.
2015 F150 2.7
2018 F350 6.2
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5218958 09/21/19 03:46 PM
B
bruckus Offline
B
I run a dehumidifier in my extra garage through the summer months. I don't open the doors very often and it stays very comfortable throughout the summer. I am insulated very well also.
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5218979 09/21/19 04:08 PM
L
L
Keeping garage door open or closed makes no difference. Open the 2 windows no change. Using a box can does help but takes a long time to dry out.I
Using the box fan before it gets wet helps but it will eventually get wet. It's a one car garage.
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219002 09/21/19 04:27 PM
F
Fitter30 Offline
F
Slab gets wet because it's cooler than the dew point. Garage must be very well insulated to keep slab cooler than dew point.
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219003 09/21/19 04:27 PM
W
wings&wheels Offline
W
Hi dehumidifier and a condensate pump
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996 (Wife's)
'01 Porsche Boxster S (mostly Wife's...)
Piper Pa28-236
Re: Garage high humidity floor wet vehicle inside. [Re: Fitter30] #5219032 09/21/19 05:03 PM
E
eljefino Offline
E
It's the way my house is, too. Just sucks. Cold comes out of the ground.
Garage is uninsulated and has semi-open soffits, but the cold concrete trumps all of that. I could run the dehumidifier 24/7 but the electric bill would be worse than the rust on my tools and vehicles.
Inside your axles is probably safe-- I'd worry about the floor pans and brake lines.
In winter, if I were you, I'd consider parking outside during the freeze/thaw cycles with high humidity. Only inside for snow prep and real cold snaps (under 10'F). There's more of a breeze under the car outside vs in a clammy dank garage. And salt is worse at the freezing point vs dry crystals at 10'F.
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219036 09/21/19 05:06 PM
T
Traction Offline
T
I also have been running a dehumidifier when it is really humid for over 20 years in my garage. I just keep it close up, things don't rust, and it almost feels like it's air conditioned when it is hot, and muggy out. I also keep frozen cars covered in snow and ice outside in the winter to keep the moisture under control. I do not ever get any rust on all of the bare steel I have laying around, or my precious tools, and cars.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219112 09/21/19 07:12 PM
L
L
Some good advice. Winter is worse then summer believe it or not. I think I will put it outside in the winter when humidity is high. Vehicle has never seen a salt road. I did coat all the brake lines with fluid film. Vehicle is 100% rust free (so far)
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219162 09/21/19 07:50 PM
A
atikovi Offline
A
Running gear is coated in oil so no problem. As long as the frame door and fenders have solid paint, no problem either. I'd be more concerned with mold on the interior. I've had a few cars with all the plastic and vinyl covered in green fuzz after a few months.
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219182 09/21/19 08:08 PM
L
L
Thanks atikovi . That's what I was hoping to hear about the body and running gear. Vehicle is a 2010 and the interior is mint (show room). Still smells new.
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219208 09/21/19 08:37 PM
PimTac Offline
You still need to get some ventilation in that garage. It’s not just your vehicles that are getting damp.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219278 09/21/19 10:02 PM
Dinoburner Offline
Had this problem in the barn. turned out to be a high ground water. Fortunately the ground slopes away out back so a perimeter drain installed about 4 feet down took care of most of the problem. Wet weather in Dec will still cause moisture on the inside of windows and tools like drill press etc.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219330 09/21/19 11:35 PM
K
Kurtatron Offline
K
I dealt with a similar issue. My summer camping vehicle is stored in my garage over winter. Last year’s winter, the brake disks were covered in rust. Worse yet, rust had creeped all over the vehicle, the valve cover, random nuts and bolts. I was so disappointed. My spotless camper car was showing its first signs of rust. I tackled the issue here on BITOG.
With the help of forum input, I determined it was due to condensation of cold bare metal with warm humid air. So all exposed metal was rusting. The solution? I thought about dehumidifiers, but the garage isn’t sealed. I considered leaving the daily driven car outside the garage, but that sure isn’t worth it in the peak of winter.
Turns out the solution was something called Car Jacket. It’s basically a sealed tarp cover. You drive the clean, dry vehicle on top the jacket, then wrap and zipper up the entire thing, like a bubble. You throw in some carbon bags to absorb any residual moisture and lock it up. I was absolutely ecstatic with the results. After 6 months of storage, the brake calipers were EXACTLY the way I left them. Tiny little rust spots from washing the car. The car Jacket is the ultimate car storage solution to prevent moisture damage without outrageous electric bills.
Re: Garage high humidity floor wet vehicle inside. [Re: littleant] #5219335 09/21/19 11:42 PM
J
JLTD Offline
J
You could try a window air conditioner for summer, and install a gas heater for the winter. Both will help mitigate moisture.
I use the overseas manual to choose my viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
His: 2015 4Runner 60k, SS 5w20/Amsoil
