what is the easy DIY brake rotor deglaze I've read using 120 grit emery cloth or green scotchbrite pads and then cleaning with brake cleaner. im about to replace my brake pads and the rotors are well within factory specs but appear a little shiney and maybe need a little roughing up to remove some glaze from previous pads. I do not plan on resurfacing or replacing the rotors since they are well within the recommended thickness and have no grooves or vibes.
