Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
82 registered members (2010Civic, bbhero, AZjeff, 55hambone, 4WD, 2strokeNorthstar, 6 invisible), 1,529 guests, and 17 spiders.
Topics301,809
Posts5,203,132
Members70,784
Steering Nibble 2018 F150 #5209332 09/10/19 02:22 PM
T
Thugzy Offline OP
T
My 2018 F150 has exhibited whats called steering nibble. Its a slight knocking vibration feeling in the steering wheel from 60kmh and as i get up in speed to 120kmh, the steering vibration gets worse as well as i feel the vibration in the chassis of the truck.
It is much more apparent when making lane changes to the left.... imagine driving straight and when you turn your wheel 2-3 degrees to the left and hold it there, the vibration feeling becomes worse..... turn the wheel back straight and the vibration is less...
I have new tires on the truck, which were road force balanced... the same problem was there with the previous original GoodYears....
Wondering if anyone else has gone through this issue.... I read Ford has active nibble algorithms in the EPAS.... so im assuming my F150 has it..but perhaps not working as intended
https://www.autotrader.ca/newsfeatur...ibble-control/
'18 F150 Lariat 3.5EB - QSUD 5W30/PG2500EX
'15 F150 Lariat 5.0 - PUP 5W30/Motorcraft
'01 S2000 - M1 0W40/Toyo Roki
'15 Q50 AWD VQ37 - M1 FS 0W40/M1 Filter
'13 Crosstrek - QSAD 5W30/Champ Filter
Re: Steering Nibble 2018 F150 [Re: Thugzy] #5209357 09/10/19 02:52 PM
M
MParr Offline
M
Is it still under warranty? If so, take it to your Ford dealership.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
2014 F-150 4x4 Now: Pro DS 5W20 & Motorcraft FL-500s
Re: Steering Nibble 2018 F150 [Re: Thugzy] #5209379 09/10/19 03:10 PM
carviewsonic Offline
Stuff like that is really frustrating.. Over the years most of my cars have been good as far as vibration issues, but I've had a couple otherwise nice cars that drove me nuts trying to fix the problem. Hopefully the dealer can quickly sort this out for you.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Steering Nibble 2018 F150 [Re: Thugzy] #5209386 09/10/19 03:18 PM
2
2oldtommy Offline
2
Could be a slightly bent wheel. Road force balancing will not pick this up. FWIW
oldtommy
Re: Steering Nibble 2018 F150 [Re: Thugzy] #5209413 09/10/19 03:47 PM
R
Reddy45 Offline
R
Since you can feel it as you turn the wheel ever so slightly left, this makes me wonder if a certain kind of alignment would help? (assuming this is just the nature of the beast)
Since you drive on the right side of the road, and most roads are slightly crowned for drainage, then the vehicle naturally wants to drift right if you keep the wheel absolutely straight. Holding the wheel slightly left would account for the crown and keep you between the lane lines.
A skilled(?) alignment shop could set a very slight bias so that you are actually holding the wheel straight when going straight, making the nibble less noticeable?
Re: Steering Nibble 2018 F150 [Re: carviewsonic] #5209439 09/10/19 04:18 PM
T
Thugzy Offline OP
T
my problem is, Ford dealerships are incompetent and dont want to spend the time to troubleshoot... ive been to 2 dealerships and they sofar said cant duplicate it.... this maybe my last ford product just due to the poor service in my area (Toronto)
Re: Steering Nibble 2018 F150 [Re: 2oldtommy] #5209440 09/10/19 04:19 PM
T
Thugzy Offline OP
T
oldtommy
ive tried swapping wheels with another truck and rotating... still same problem
Re: Steering Nibble 2018 F150 [Re: 2oldtommy] #5209679 09/10/19 09:15 PM
R
rubberchicken Offline
R
oldtommy
Road force balancing "should" pick this up, but I have witnessed lazy techs who ignore it.
Re: Steering Nibble 2018 F150 [Re: Thugzy] #5209953 09/11/19 08:15 AM
DriveHard Offline
bad wheel bearing
wheel bearing with excessive run-out
bad CV joint
stock rims, or aftermarket?
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Steering Nibble 2018 F150 [Re: DriveHard] #5210168 09/11/19 01:10 PM
T
Thugzy Offline OP
T
Originally Posted by DriveHard
bad wheel bearing
bad CV joint
stock rims and tires... im thinking front bearings
Re: Steering Nibble 2018 F150 [Re: Thugzy] #5210196 09/11/19 01:50 PM
M
mk378 Offline
M
Lift the wheel off the ground and rock it back and forth by hand to check for any looseness. With truck on the ground, look underneath while someone turns the steering wheel slightly side to side. Look for slack in parts that move without the tire moving.
Re: Steering Nibble 2018 F150 [Re: mk378] #5210218 09/11/19 02:11 PM
T
Thugzy Offline OP
T
did all of that... no issue found
Re: Steering Nibble 2018 F150 [Re: Thugzy] #5210900 09/12/19 10:57 AM
H
Huie83 Offline
H
I can't offer any advice that will fix the actual issue.
However, my mom went through a similar issue with a new Chevy 3500 they purchased a few years ago. They had a intermittent drive line vibration in the rear from new. They tried new tires, different wheels, new driveshaft etc, the truck was in the shop I believe 10-12 times while they tried to fix it over a year time span. Sometimes with a "cannot duplicate" outcome.
Finally they got tired of it and couldn't spend more time bringing it in. They approached the dealer tactfully and were treated fair on trade for another new truck. Problem solved. The dealer stepped up and saved the brand for them, if not they would probably be driving something besides Chevy. Do they wish the truck could have been fixed, yes. Is life always perfect, no. They've been happy with the new one for a few years now.
Re: Steering Nibble 2018 F150 [Re: Thugzy] #5210920 09/12/19 11:35 AM
T
The_Eric Offline
T
Get it up in the air, turn traction control off and drive it. Switch between 2wd and 4wd, apply brakes to simulate load on front cv joints. Try to narrow it down that way. Perhaps remove or swap front axles to see it the vibration changes or follows side to side.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Steering Nibble 2018 F150 [Re: The_Eric] #5211105 09/12/19 03:38 PM
T
Thugzy Offline OP
T
dealer is trying new front wheel bearings and IWEs...
