Originally Posted by tenderloin
Above I posted a photo of a '17 Escape dash (with Sync 3) that shows oil % info as well as posting that the Ford Pass app has the same information. Not a made up/doctored photo. Our friends 17 shows the info as well. Either you are entering commands improperly or your Escape has a problem, not the '17 Escape Sync 3 combination (which makes IMO no sense at all anyway)
Instructions
Left arrow
Settings...OK..scroll down
Vehicle...OK...scroll down
Oil LIfe Reset...OK... (shows %)
Thanks, I am going to give this a try shortly. It is past 1 am but this has really been bothering me.
OK, I tried it, there is no "oil life reset" option. I forgot to mention that at least for this 2017 Escape, it requires holding down the brake and gas pedal at the same time for 20 seconds.
CRAP NUTZ !@#$!@#$!@#$ - This seems to explain the inconsistent behavior- apparently I never found this before in all my searching- can anybody confirm this ?
Oil Change Indicator Reset Procedure - 2017 Ford Escape
oemdtc February 26, 2018 Info
SSM 47108 - 2017 Escape - Oil Change Indicator Reset Procedure
2017 Escape vehicles built on or before 18-May-2017 are not equipped with an instrument cluster that can reset the oil change indicator.
2017 Escape vehicles built on or before 18-May-2017 must use the oil change indicator reset procedure outlined in Work Shop Manual (WSM) section 413-01 under general procedures.
2017 Escape vehicles built after 18-May-2017 have the ability to reset the oil minder through the cluster using the oil change indicator reset procedure listed in the owners guide. (implies the owners manual is wrong)
https://ford.oemdtc.com/3467/oil-change-indicator-reset-procedure-2017-ford-escape
