CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Key FOB Will Only Open Doors
by Gebo - 02/20/20 03:47 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
29 registered members (Arrechera, Bailes1992, 2015Corolla, Bighorn2500, avi1777, bachman, 3 invisible), 1,014 guests, and 16 spiders.
Topics301,732
Posts5,201,554
Members70,763
Starter Replacement in 2012 Frontier #5205625 09/05/19 05:30 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I just had my starter replaced in my 2012 Frontier with a Duralast starter.
Let's hope the Duralast outlasts the OEM part. shocked2
The solenoid would pull in (you could hear the click) but no cranking.
Luckily it died in the driveway so the tow truck had no problem lifting it.
It is located close to exhaust parts and even though there are two heat shields, it must have become, "cooked."
BBQed starters don't look or operate so well. grin2
I'm a Student Pilot. Frightening, isn't it?
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205641 09/05/19 05:52 PM
U
user52165 Offline
U
"Let's hope the Duralast outlasts the OEM part."
Never happen. OEM is best.
Dis you consider fixing it? Often simple and cheap.
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy. It's inherent virtue is the equal sharing of misery.
Winston Churchill.
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205655 09/05/19 06:07 PM
A
andyd Offline
A
7 yr old original starter isn't awful. Have you turned the old in for core charge or are you gonna get it rebuilt?
Thick oil is better grin2
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205662 09/05/19 06:18 PM
T
Trav Offline
T
Yes, they are rebuildable at home but only if the field winding insulation didn't get cooked and short which is very possible from what you describe. Armature winding are usually okay unless the commutator get damaged but that is replaceable too a simple growler test will check it..
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205672 09/05/19 06:37 PM
M
maxdustington Offline
M
Frontier = BITOG's truck!
99 Toyota Tercel CE 5EFE/C151
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205685 09/05/19 06:48 PM
K
kc8adu Offline
K
iirc the contacts fail.
a set is $10 shipped.
easy to replace.
some just flip the main one over and use it up.
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205750 09/05/19 08:23 PM
1
14Accent Offline
1
Good luck with the Duralast... had a customer in today that had their starter replaced a week ago with a white-box starter at another shop. Already junk.
I will only use one of those when the customer asks for the cheapest of the cheap. Otherwise, I go to my local rebuilder every time for starters and alternators.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205756 09/05/19 08:33 PM
L
Lolvoguy Offline
L
Nothing grinds my gears more than short-sighted designs like that.
My Focus had the same issue but with the alternator mounted at the back of the engine, with the exhaust mani right below it.
Luckily I disposed of the car before it required replacing.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205884 09/06/19 03:58 AM
P
Popsy Offline
P
7 years isn't too bad IMO.
For sure they don't last as long as before, but like you say the location plays a big role...and new engines/cars with packed engine bay and high power density engines don't help.
My 23 and 21 yo Fiats have the starter sitting almost at the bottom rear of the engine, the diesel is still on the OEM Magnetti Marelli starter, but the Barchetta got a new Bosch starter recently.
The rebuilder told me it wouldn't have been worth a rebuild, now I'm unsure about that! The geared crown/pinion that engages into the flywheel (worry for bad English) was very worn out and they couldn't locate a suitable replacement.
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, Castrol 0W30 | Colt Ralliart, 300V 5W40
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5206286 09/06/19 12:09 PM
Silverado12 Offline
I had a 1996 Chevy S-10 4 cyl that ate starters for the same reason. The exhaust manifold had to come off to access the starter.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Starter Replacement in 2012 Frontier [Re: user52165] #5206466 09/06/19 04:18 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I usually rebuild all of our starters and alternators, but in this case I needed to lift it high enough to remove all of those heat shields and have enough room for removal, but did not have the lifting capability so I had my mechanic change it.
BTW, this is a geared and rather small size starter with a permanent magnet field system. So it still has brushes to energize the rotating armature. It turned out the brushes were ok but worn, but the wiring in the armature had shorted.
Re: Starter Replacement in 2012 Frontier [Re: Silverado12] #5206470 09/06/19 04:21 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I have a 1999 S-10 V6 that is on its second starter.
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5346780 02/10/20 11:29 PM
MolaKule Offline OP
Global Moderator
Global Moderator
UPDATE: Well, the DuraLast reman didn't last long as it failed back in January.
This time I opted for a new starter and since the reman had a 2 year warranty on it it cost me $34,00 to get a new one.
The new starter spins faster and the engine starts within like 1/4 a second.
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5346786 02/10/20 11:41 PM
Deontologist Offline
I put a Pep Boys Bosch reman in an old Camry. I then immediately put 12,000 miles on the car in 3 months from Ubering around with it.
That Bosch starter never skipped a single beat despite being a $120 reman. I must have started the car at least 10-15 times a day.
Toward the end I just started shutting off the car whenever possible, even if I had to jump into the gas station for a minute to buy a drink. Figured that I'd save some gas and I wanted to push the starter to the ragged edge.
