it has Active Fuel Management so that is why i'm worried a bit
I use chevron or Mobil 91 octane
so knocking or pre detonation is not really a issue
know AFM does not play nice with bad oil or "used up" oil..
The highest RPM i normally do is 2500RPM from a
STOP SIGN Freeway entrance other wise I keep it 1000 to 1600 rpm under normal driving conditions(sometimes 1800rpm, that will do AFM @80MPH @ 1800RPM on flat land)
Well if you are worried about carbon build up the worst thing you can do is baby the vehicle and you are not gaining anything by using 91 octane.
VVT as well for extra power
Yes it can take advantage of it i have seen the Timing advance @ 42 degrees advancement .. (from live data stream) AFM does not have that stutter or shutter AFM knock.
better fuel mileage on the HIGHWAY makes it worth it i get 23.5 to 26MPG on the highway with 91 octane
with 87 octane it will get EPA MPG 19 so unless 87 drops below 3.099 a gallon it's not worth my time current price is 3.39 at the cheapest station near by
If this were true GM would recommend using 91 octane the extra 20%+ of fuel economy helps their CAFE.
Not a lier check out my Fuelly log
the dip are my city milage it's been less lately (short trips don't help) as I been using the A/C FULL blast
Front and REAR A/C keeps my SUV as cold as a ice box
(keeps the engine going in the city) well it has been over 100F every [censored] day
http://www.fuelly.com/car/chevrolet/tahoe/2008/brent88/905265
