wemay
Site Donor 2023
Originally Posted by edyvw
Originally Posted by 2003f7
My Tucson is a 1.6 turbo with D.I.
Use ACEA A3 or C3.
You have Pennzoil Platinum Euro L in Wal Mart. It is MB 229.51 and better than ANY ACEA A5.
better,stronger ex sure but isnt it over kill?
What is overkill? HTHS of Mobil1 5W30 EP is 3, PP Euro L is 3.5. That is the most important thing for turbo application.
Also, PP Euro L is approved against MB 229.51, which means much better deposit control, NOACK limited to max 10% (PP Euro L is GTL based, so in 5W30 application NOACK is probably in range around 7%. BMW TPT 5W30 that is made by SOPUS has NOACK 6.8%. Some argue that PP Euro L is actually same oil as BMW TPT 5W30). So, I am not sure you can characterize lower NOACK, deposits etc. as "overkill."
On top of that, PP Euro L in Wal Mart is $22 for 5qt, while Mobil1 5W30 EP which is ACEA A5 is $25.
Plus, it's (PP E L) low sulphate ash. Hence the "L" in the name.
Use ACEA A3 or C3.
