Dollar General: LA's Awesome Orange 1 gall~$2.25
by dwcopple - 04/02/20 07:05 AM
Are all JWS3309 ATF’s the same?
by dlundblad - 04/02/20 05:03 AM
Shell selling rebranded Pennzoil in Europe?
by FordCapriDriver - 04/02/20 02:54 AM
Mitsubishi Mirage for Basic Transportation
by parimento1 - 04/02/20 12:54 AM
Amsoil EaOM103
by Lufty - 04/02/20 12:46 AM
Wheel bearing grease discussion
by Zahndkile - 04/01/20 11:10 PM
Low mileage Hundai Kona 5w-20 or 5w-30?
by j_mac - 04/01/20 10:43 PM
Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
AConstructionGuy, MPDano, ferdna, Code, Adam1
71077 Registered Users
90 registered members (antone, 94astro, 5AcresAndAFool, 10ecfarmer, 18LateModelFan, andyd, 10 invisible), 1,204 guests, and 18 spiders.
Topics303,473
Posts5,235,785
Members71,077
Page 3 of 5 1 2 3 4 5
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: panthermike] #5186298 08/13/19 06:59 PM
caprice_2nv Online Content
Online Content
Originally Posted by panthermike
blupupher- cost partially as well as what the warranty company will pay for. I really didn't want to fight with Ford to use my own part on their motor.
Ahh, OK, so not your dime, I can understand that. Even then, the newer OEM parts do address some of the issues, just not quite as well as something like the Melling pump would.
Again, I personally would just use a cheap synthetic 5w-20 and change every 4000 miles or so. It is what I am doing with my BIL truck.
I could understand the desire to use a name brand 5w-30 synthetic though, my brain still thinks that way some times, but regardless, I would lean toward shorter OCI instead of longer (or even recommended).
This is part of the reason I say use a cheap syn oil, regardless of which oil brand or weight is used, 4000 miles is about the limit on these things. the long timing chains, hydraulic adjusters, VCT solenoids, phasers, just a lot of stuff going on in these things that can be hard on oil.
Hey i appreciate the feedback, i've heard go with a shorter oci but wasn't sure how short. This helps, and makes total sense why you mention to use something cheap!
I would go shorter than any other engine you can think of that needs frequent oil changes, because these are one of the most likely engines to fail IMO.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: caprice_2nv] #5186486 08/13/19 11:09 PM
dave1251 Offline
No this engine is historically robust significantly more reliable than the industry average.
don't use.
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: panthermike] #5186570 08/14/19 05:27 AM
B
Bjornviken Offline
B
Mobil1 0w-40
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: panthermike] #5186677 08/14/19 08:18 AM
F
FastLane Offline
F
5.4 is not robust. They fail often and early. Take care of it. There is a reason why you cant find them used. You don't need a HV oil pump. Its nice but way over priced.. I would say the standard volume Melling pump is a million times better than the Ford. I have one sitting in my garage to swap over in my 4.6 when I do the timing chains.
2010 Silverado 4.8 4x4 Mobil 1 5W30 Fram XG10060
2002 Mustang GT 4.6 Mobil 1 5W30 Fram XG2
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Lund SV16
2007 Yamaha Nytro
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: FastLane] #5186846 08/14/19 10:41 AM
dave1251 Offline
You are just plain wrong with your opinion.
don't use.
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: panthermike] #5186923 08/14/19 12:08 PM
M
mrjlube Offline
M
How do you know that the 40 weight oil did not cause your problem? It serms everyone is scared of 5w20 oils. Stick with what the manual says and drive that sucker for 200,000 miles👍 I was scared of it also until gaining valuable knowledge on this site. This is a fun hobby for me.
2017 Ford Escape ...ValvolineSynthetic 5w20
2009 kymco xciting 500...amsoil scooter oil...10w40
2001 Honda civic 5 speed 1.7.....Valvoline Maxlife 5w30
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: mrjlube] #5186940 08/14/19 12:31 PM
P
panthermike Offline OP
P
Well I think it's very unlikely that ANY weight oil caused this issue; 20 or 40. This failure is not common i would say but there are examples of this specific failure out there with the 3V. All the issues I experienced pre-failure were prior to me trying 40w and with 20w in the sump. Again though; the failure was going to happen regardless.
I normally have no issue running what is spec'd but from my reading/research the 30w works well in the 3V(or at least certainly doesn't hurt).
Here's my thread when I knew something was up:
https://www.bobistheoilguy.com/foru...f-150-5-4-3v-issues-imminent#Post5064089
'17 Armada Platinum; RGT 0w20, 52K
'19 Ram 1500; RGT 5w20, 15K
'70 F100; Valvoline 15w40
Biotech For All
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: dave1251] #5187578 08/15/19 06:34 AM
Online Content
What?! You're crazy.
79 Honda CX500
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: panthermike] #5187582 08/15/19 06:40 AM
Online Content
79 Honda CX500
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: panthermike] #5187800 08/15/19 11:08 AM
P
P
Hate to say it since I own one, but agree with caprice; they're not as good as the 2V for sure. Seems hit and miss though; my brother has the 3V in his '07 F150 and it has been trouble free for 175K miles, pretty ugly maintenance records to.
Biotech For All
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: panthermike] #5187819 08/15/19 11:32 AM
BlueOvalFitter Offline
OP, what's the status on your truck and new engine install?
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: panthermike] #5187822 08/15/19 11:36 AM
G
gfh77665 Offline
G
I have always wondered what s the true likelihood of having the 5.4L problems? Is it 10% of the Fords? 5%? 1%? 0.1%?
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: caprice_2nv] #5187828 08/15/19 11:42 AM
dave1251 Offline
Originally Posted by caprice_2nv
There are about 2 million examples of this engine and the failure rate before 150K miles is below 3%. Did you account for this?
don't use.
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: panthermike] #5187846 08/15/19 12:00 PM
dave1251 Offline
Think of it like this everyone in Phoenix could have one and there would be enough to give one to everyone in Tucson. There view you and Caprice is representative of a fraction of a percentage getting caught up in the micro view when making an statement as the whole is far from wise.
don't use.
Re: 5.4 3V New motor- 5w30 or 0w40? [Re: dave1251] #5187869 08/15/19 12:35 PM
P
P
I wouldn't disagree with you there Dave. I think my feeling is more so not that it's "unreliable" but just has some weak design points as compared to the 2V. Or I guess more complexity is another way to put it. But again, I know there's a ton of these motors and a bunch with high miles. Actually there's a gentleman on YT that claims to have 600K on his '09, original engine/trans.
Biotech For All
