Originally Posted by Cujet
Originally Posted by Ws6
Because a liquid-cooled engine can be properly designed to be MUCH more efficient, as the coolant can be routed to "hot spots", etc.
Maybe, maybe not. Air cooled engines may run with cylinder head temperatures as high as 500 deg F. This means less combustion energy is wasted into the cooling system. Aircraft engines are air cooled and have been able to match the thermal efficiency of a Prius engine for the last 70 years.
You have no idea what you're talking about. Letting an engine run hotter does not mean less combustion energy is wasted, it just means more stress on the engine. On the contrary you want a controlled temperature to maximize a lean fuel ratio.
Aircraft engines are only air cooled for two reasons. One, there's a massive amount of air to do that. Two, they care about simplicity in failure modes and maintenance more than efficiency.
"Thermal efficiency" is a completely nonsensical concept. Neither has a method of turning waste heat into power.
If you maintain a consistent temperature then you can optimize the fuel mix ratio and the timing. Either way a colder cylinder air temperature pre-compression, is denser, and the compression ratio determines the power, while hotter would just cause a retarded timing detriment if the engine can adjust instead of knocking.
No, no, no. It's nonsense. There are emissions regulations and the only way combustion "energy" serves any useful purpose is if you add weight for an extraction system that can convert it into either propulsion force or battery charge, either adding weight when the criteria for an airplane is keeping weight down.
Thermal efficiency of a prius engine? You have no idea what you're talking about. None. Heat is not directly converted into power, it's just not applicable. The only similarity is for both to run in an optimal power curve RPM for efficiency, airplanes being optimized for their cruising speed.
Everything you suggested, is ridiculous.
