2018 Ford 2.0 EcoBoost
by mpgo4th - 02/28/20 03:30 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
115 registered members (762fermeandyou, AlienBug, 28oz, 4WD, 01rangerxl, 2K2AcuraTL, 7 invisible), 2,223 guests, and 14 spiders.
Topics302,048
Posts5,207,999
Members70,825
15 Forester 2.5 PP 5w-30 whirring at 1500rpm #5185571 08/13/19 04:44 AM
M
MoneyJohn Offline OP
M
2015 Forester 2.5 calls for 0W-20 oil. I have been using 5w-30 during the summer for the last 3 years. Last 2 years I used PUP. I had no issues whatsoever, never felt any difference due to the different weight oil.
This year I could not find it on the shelves so got Pennzoil Platinum 5w-30. Since I put this oil, there is a subtle whirring sound at 1500 rpm. I am not able to describe the sound exactly but feels like there is more friction somewhere. I can feel that vibration in the accelerator pedal. I do not hear the sound or feel anything in the pedal below or above 1500rpm.
There is no other difference. The car drives just fine. The mileage is pretty much the same.
Any idea what am I dealing with? The easiest option would be to change the oil back to 0w-20. This oil has 4000 miles on it (~80% highway miles) and next planned oil change is in late Oct. What should be the best course of action here?
Thanks in advance.
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: MoneyJohn] #5185580 08/13/19 04:56 AM
J
jbutch Offline
J
I really, really doubt it has anything to so with the oil. PUP and PP are very similar anyway.
Sounds like something else, engine mounts? CVT?
How much mileage?
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: MoneyJohn] #5185581 08/13/19 04:56 AM
demarpaint Offline
Did you use the same brand oil filter? It could be a mechanical issue. Different brand filter, I might consider changing back to what was used previously.
God Bless Our Troops
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: MoneyJohn] #5185610 08/13/19 05:38 AM
M
M
@jbutch, the mileage is 35310. I hope it's not CVT
@demarpaint, I have only used the Subaru oil filter, change it at every oil change.
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: MoneyJohn] #5185635 08/13/19 06:07 AM
A
ARCOgraphite Offline
A
Thanks in advance.
Might be fluttering ADBV. Try a different filter. Easy to change.
I havent been happy with some of the new formulation and dexos stuff. Its not quite right in some engines. To many changes with out enough proving.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: MoneyJohn] #5185952 08/13/19 11:54 AM
B
benjy Offline
B
engine oils rarely cause issues when changed on a timely basis except when a very thin read 20W is pushed to hard + it thins to a 10W. newer subies are not as good as older ones especially if it has a constantly variable troublesome tranny!!
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: MoneyJohn] #5185959 08/13/19 11:59 AM
demarpaint Offline
Then I doubt the problem is with the oil or the filter.
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: MoneyJohn] #5185965 08/13/19 12:03 PM
PimTac Offline
I would check underneath the car. Is the splash shield secure? Maybe you picked up something on the road that got stuck underneath and is causing this noise?
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: MoneyJohn] #5185997 08/13/19 12:32 PM
A
A
We had mice under the intake. there is quite a large flat mouse motel area under there.
Then you have VVT giving up the ghost and cam tensioners sticking.
All this seems to happen with a dry start after an oil change.
Of course These top filter are ALWAYS EMPTY in a couple minutes after shutdown.
It could be timing chain racket. Happens all the time. - except on small Honda 4 bangers.
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: ARCOgraphite] #5186015 08/13/19 12:54 PM
V
Virtus_Probi Offline
V
I gotta disagree with you here, ARCO!
My daughter complained that her Impreza was hard to start after sitting all day at school just after my wife got it a cheap oil change where they used a filter with no ADBV....I put a Subie blue can or WIX 57055 (can't remember which) in it and no more complaints.
When I do a change on my FXT, a lot of oil still comes out of my filter after I drain the pan....I'd guess it's usually about 10 minutes between pulling the plug and taking the filter off.
I think the ADBV maintains a column of oil for a long time even with the top mounted filter.
IDK, maybe some weird gravitational effect from you being further North than me and closer to the mountains in NH?
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: ARCOgraphite] #5186025 08/13/19 01:04 PM
J
jbutch Offline
J
A high quality silicone ABDV made a huge difference versus the stock nitrile one on cold startup.
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: MoneyJohn] #5186764 08/14/19 08:22 AM
A
A
Over three engines during multiple OC's, never, EVER was there substantially any oil in the filter when removed. All being Framaroo Blue cans.
It must be the Magnetic North effect smile
So, Jbutch You recommend the Fram XG in your signature?
I think it's too late for this engine - I'm not going aftermarket with it acting up.
It has one of those silly dealer "Lifetime engine warranties" Maybe will wee see if that's really worth anything.
Re: 15 Forester 2.5 PP 5w-30 whirring at 1500rpm [Re: ARCOgraphite] #5186979 08/14/19 12:09 PM
J
jbutch Offline
J
It's the first I use it, definitely feels more robust and I seen a lots of C&P and they all seems fine.
Only downside is that it is not the correct bypass pressure. But supposebly it has more flow.... not too worried about that.
