Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
Ford to reduce warranty costs ?
by marine65 - 02/27/20 06:02 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
61 registered members (2015_PSD, Astro_Guy, AurionX2, alarmguy, 2010Civic, Amkeer, 12 invisible), 1,120 guests, and 17 spiders.
Topics302,027
Posts5,207,528
Members70,819
What is a good way to clean this cylinder head? #5169093 07/23/19 04:10 PM
Z
zzyzzx Offline OP
Z
I'd like to clean up a previous oil leak, including the spark plug wells. Should I use a pressure washer???That and how do I clean the exhaust manifold mating surface?
[Linked Image]
Re: What is a good way to clean this cylinder head? [Re: zzyzzx] #5169094 07/23/19 04:16 PM
skyactiv Offline
Take it to a machine shop and have them check it out, too.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: What is a good way to clean this cylinder head? [Re: zzyzzx] #5169142 07/23/19 05:33 PM
A
atikovi Offline
A
Nobody pulls a head to clean up an oil leak. What's the whole story?
Re: What is a good way to clean this cylinder head? [Re: atikovi] #5169159 07/23/19 06:04 PM
Z
zzyzzx Offline OP
Z
I am replacing the head gasket gasket.
Re: What is a good way to clean this cylinder head? [Re: zzyzzx] #5169174 07/23/19 06:19 PM
sloinker Offline
Looks aluminum...maybe a big bucket of old time Berryman carb cleaner. The stuff that worked back in the day and made me gag with its smell.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: What is a good way to clean this cylinder head? [Re: zzyzzx] #5169175 07/23/19 06:20 PM
A
Audios Offline
A
Have the machine shop pressure test and clean it, along with a cut.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: What is a good way to clean this cylinder head? [Re: Audios] #5169215 07/23/19 06:50 PM
T
Trav Offline
T
+1 That is the way to go, pick it up all done, clean and flat.
Re: What is a good way to clean this cylinder head? [Re: zzyzzx] #5169220 07/23/19 07:00 PM
A
atikovi Offline
A
So what is it? Old style rocker arms suggests a domestic. Cam drive pulley so not a V8 but OHC 4. 2 valve aluminum head. 80s or early 90s GM?
Re: What is a good way to clean this cylinder head? [Re: sloinker] #5169221 07/23/19 07:01 PM
clinebarger Offline
That would destroy the valve guide seals! Though I would recommend replacing them anyway.
2001 Chevy Camaro L92/4L80E
Re: What is a good way to clean this cylinder head? [Re: atikovi] #5169235 07/23/19 07:10 PM
Z
zzyzzx Offline OP
Z
1995 Ford Escort with 1.9L engine.
Re: What is a good way to clean this cylinder head? [Re: zzyzzx] #5169247 07/23/19 07:32 PM
R
Roadkingnc Offline
R
I would have the valves and seats checked, those were known to drop valve seats which males for a bad day
Re: What is a good way to clean this cylinder head? [Re: Roadkingnc] #5169264 07/23/19 07:46 PM
Z
zzyzzx Offline OP
Z
Totally not necessary. Jasper already did this.
Re: What is a good way to clean this cylinder head? [Re: zzyzzx] #5169321 07/23/19 09:03 PM
V
Vern_in_IL Offline
V
I would use a die grinder with scotch pads attachment. Or just scotch pads with manual labor from my hands, perhaps a wire brush.
and then use a Starrett metal ruler and feeler gauges to check for flatness.
if needed find a piece of glass and lay down a sheet of sand paper (4000 grit) and do some poor boy garage machining. I use a surface plate, and use those 6" "stickey" orbital sanding disc, and I can get things very flat.
Re: What is a good way to clean this cylinder head? [Re: zzyzzx] #5169423 07/24/19 04:34 AM
L
Linctex Offline
L
Just a wire wheel in a drill, and Scotchbrite. Take your time, don't get aggressive
chase the threads if needed
anti-sieze on all bolts that thread into aluminum
Re: What is a good way to clean this cylinder head? [Re: zzyzzx] #5169547 07/24/19 08:09 AM
Donald Offline
Years ago when I rebuilt my Mustang's 289 engine you could bring it to a machine shop and have it "hot tanked".
2015 Ford F-250 w/Powerstroke
